New thread for my 37 #2310094
05/24/17 12:03 AM
05/24/17 12:03 AM
Dreaming of the 808
AZ_A12_BEE Offline OP
Dreaming of the 808
I starting a new thread on my 37 Plymouth pickup and its transformation from marginally driveable with a 289/C4 to a 6.4 Hemi/545RFE/4.10 Dana 60 monster.
Today I dropped it off for getting a 4 inch mini-tubs in the bed so the bed is even with the frame rails so I can fit these 295/50/15s on 10 inch wheels under the truck. The next step will be to order a narrowed Dana 60 with 4.10 gears so we can do the 4 link rear.
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: New thread for my 37 [Re: AZ_A12_BEE] #2310100
05/24/17 12:10 AM
05/24/17 12:10 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
popcorn
This should be good. up
Re: New thread for my 37 [Re: moparpollack] #2310121
05/24/17 12:33 AM
05/24/17 12:33 AM
Dreaming of the 808
Dreaming of the 808
Originally Posted By moparpollack
popcorn
We are going to do it in stages, get the rear 1/2 of the truck done first then tackle the front including doing the motor and trans along with a Mustang II front suspension, 4 wheels discs as well
Re: New thread for my 37 [Re: AZ_A12_BEE] #2310124
05/24/17 12:37 AM
05/24/17 12:37 AM
Dreaming of the 808
Dreaming of the 808
What do you guys think of these brakes for the rear?
Re: New thread for my 37 [Re: AZ_A12_BEE] #2310236
05/24/17 10:18 AM
05/24/17 10:18 AM
AZ
Mike P Offline
Mike P  Offline
AZ
Those tires are going to look great under there.
"........4 inch mini-tubs in the bed so the bed is even with the frame rails so I can fit these 295/50/15s on 10 inch wheels under the truck....."
Yeah , I had to go look under the back end of mine. That would be a fairly easy job to pick up a bunch of tire clearance. work
Those brakes should be plenty for the truck.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
Re: New thread for my 37 [Re: AZ_A12_BEE] #2310370
05/24/17 02:29 PM
05/24/17 02:29 PM
VA
41MoChev Offline
41MoChev  Offline
VA
Looks like it will be awesome. Tires & brakes look perfect and swapping out the old Ford 289 for a 6.4 Hemi is a big plus! Good luck with the build.
Building '41 Chevy street rod with Mopar LA power. I tell my Chevy buddies it's on the Chevrolet improvement Program.
Re: New thread for my 37 [Re: Mike P] #2310397
05/24/17 03:13 PM
05/24/17 03:13 PM
Dreaming of the 808
Dreaming of the 808
Milke, I don't think you can find a much easier vehicle to mini tub
Re: New thread for my 37 [Re: 41MoChev] #2310399
05/24/17 03:15 PM
05/24/17 03:15 PM
Dreaming of the 808
Dreaming of the 808
I got the crate Hemi about 6 months ago, hope it's sitting in the truck by August
Re: New thread for my 37 [Re: AZ_A12_BEE] #2310408
05/24/17 03:30 PM
05/24/17 03:30 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Regarding the rear brakes, let whom ever is building your Dana know what brakes you wan to run so they can use the correct housing ends and axle offsets.
As for how they work, well got a 98 Exploder with those brakes and they seem to work fine.
Don't be the exception.
Re: New thread for my 37 [Re: Supercuda] #2310559
05/24/17 08:35 PM
05/24/17 08:35 PM
Dreaming of the 808
Dreaming of the 808
Definately will let the rear end builder know, I need just a bare housing with axles to do the 4 link, then I will have it all powdercoated before it gets gears
Re: New thread for my 37 [Re: AZ_A12_BEE] #2311808
05/26/17 11:55 PM
05/26/17 11:55 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Re: New thread for my 37 [Re: RodStRace] #2311874
05/27/17 02:41 AM
05/27/17 02:41 AM
Dreaming of the 808
Dreaming of the 808
Originally Posted By RodStRace
John, I already own the crate 6.4 and 545RFE
Re: New thread for my 37 [Re: AZ_A12_BEE] #2312452
05/28/17 04:31 PM
05/28/17 04:31 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Yes, you have the fresh new good stuff.
I just mentioned it due to:
1. Additional parts you might want (driveshaft core, accessories, harness connectors, TPPS, etc.)
2. Having an engine/trans to fit without worrying about damaging the fresh stuff.
I assembled a 340 once starting with just a block, crank and rods. It ended up costing more in time and money than if I had just started with a complete motor. That's why I tend to look for stuff like I posted, even if I end up with more stuff laying around. And my yard proves it!
The project sounds great and should be quite a handful when complete.
Re: New thread for my 37 [Re: AZ_A12_BEE] #2313244
05/29/17 09:48 PM
05/29/17 09:48 PM
Az
Crizila Offline
Crizila  Offline
Az
Angled 4 link or straight with a pan hard bar?
Fastest 300
Re: New thread for my 37 [Re: Crizila] #2314806
06/01/17 09:28 PM
06/01/17 09:28 PM
Dreaming of the 808
Dreaming of the 808
I haven't decided yet
Re: New thread for my 37 [Re: AZ_A12_BEE] #2314807
06/01/17 09:29 PM
06/01/17 09:29 PM
Dreaming of the 808
Dreaming of the 808
Mini tub progress
Re: New thread for my 37 [Re: AZ_A12_BEE] #2314808
06/01/17 09:30 PM
06/01/17 09:30 PM
Dreaming of the 808
Dreaming of the 808
More
Re: New thread for my 37 [Re: AZ_A12_BEE] #2314810
06/01/17 09:32 PM
06/01/17 09:32 PM
Dreaming of the 808
Dreaming of the 808
Last
Re: New thread for my 37 [Re: AZ_A12_BEE] #2315234
06/02/17 06:43 PM
06/02/17 06:43 PM
Dreaming of the 808
Dreaming of the 808
Picked up this Dana 60 today for $100 to be narrowed, it's pretty clean, came out of a 73 Ford F-250
Re: New thread for my 37 [Re: AZ_A12_BEE] #2315242
06/02/17 06:53 PM
06/02/17 06:53 PM
Dreaming of the 808
Dreaming of the 808
Mini-tub progress, it's looking great
