Video from tonight, and some carnage Followed. #231003
02/21/09 01:55 AM
02/21/09 01:55 AM
Las Vegas
afxcoronet Offline OP
Las Vegas
Well, been making some changes to my car the past few weeks since I've been home and finally made it out. replaced the front shocks w/ a set of AFCO double adjustables, and added a set of Mufflers to it. Ran the best it has ran in years, only made one pass untill the carnage began. With help from Eric Paul(Irun6snd8th)and Troy, I tried some new stuff and finally got the car to react to changes, still waiting on my new torsion bars, but I'm convinced it's moving in the right direction...The first video it went 1.33 60' on a marginal track and ran the best it has in 2 seasons, 6.07 @112, left pretty dang hard...
Enjoy the video...
Second time run, was still in the wheel stand when I heard the ring and pinion come apart...this is the second set of gears I've broke in this Dana 60, and these are 4.30 Progears...Was told it did an even higher wheel stand in the second run...
Gonna replace the dana w/ a Ford 9" I'm done messing w/ this thing, this tranny has bolt in sprag and stuff, so kinda curious how that's gonna look...Then gonna work on the shock tuning a bit to calm it down, just happy it reacted to changes...
I'm down, but not for long, gotta keep pushing forward in order to make big things happen...
Curtis
Taking over the World one win light at a time.
Re: Video from tonight, and some carnage Followed. [Re: afxcoronet] #231004
02/21/09 02:47 AM
02/21/09 02:47 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Car sounds good..Man I miss San Antonio had a great time while there. Good to hear you made it back out after playing in the sandbox. Sorry for the carnage but it dont sound to bad.
Re: Video from tonight, and some carnage Followed. [Re: afxcoronet] #231005
02/21/09 02:54 AM
02/21/09 02:54 AM
Canada
CrAzYMoPaRGuY Offline
Canada
Curtis
Make sure you use the absolute BEST parts possible with a 9".
I blew up a half dozen fresh Ferd 9" rears , both WAR and nodular cases, everything new every time, different brands of gears, different guys setting them up etc.... 31 spline.
This was a 3100 pound street car on street tires with a very mild hydraulic cam 440.
CrAzYMoPaRGuY
Re: Video from tonight, and some carnage Followed. [Re: afxcoronet] #231006
02/21/09 07:59 AM
02/21/09 07:59 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Nice leave/run. Sorry to hear about the gears.....I must be one of the lucky ones(so far anyhow) as my lowly 8 3/4`s still holding up running low 10` for years street/strip w/30 spline dutchman axles.
Re: Video from tonight, and some carnage Followed. [Re: Thumperdart] #231007
02/21/09 08:08 AM
02/21/09 08:08 AM
Wisconsin
Garceau Offline
Garceau  Offline
Wisconsin
Its impossible....everyone here will tell you its impossible to break a Dana 60. Even one with pro gears, the girdles, and set up by a professional shop.
Ditch that heavy pig of a rear and put a real racing rear end in it and be done with it.
Re: Video from tonight, and some carnage Followed. [Re: afxcoronet] #231008
02/21/09 09:58 AM
02/21/09 09:58 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Sounds good and a nice launch to bad you broke
Re: Video from tonight, and some carnage Followed. [Re: MR_P_BODY] #231009
02/21/09 10:37 AM
02/21/09 10:37 AM
Las Vegas
Las Vegas
Thanks you all, was rather disappointing. I got a plan, and will be making some phone calls Monday morning, hope to be back out in about 2 weeks w/ a 4.30 geared 9".
Hey Kevin, give me a call today...
Curtis
Re: Video from tonight, and some carnage Followed. [Re: afxcoronet] #231010
02/21/09 10:57 AM
02/21/09 10:57 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Nice video, car looks good, sounds good and I'm jealous of that launch! You've probably been asked a million times but what's the engine combo and race weight?
Re: Video from tonight, and some carnage Followed. [Re: afxcoronet] #231011
02/21/09 11:00 AM
02/21/09 11:00 AM
NC
440Jim Offline
440Jim  Offline
NC
The car sounds nice and leaves the starting line well.
Sorry to hear about the Dana gear breakage. You are already changing, but for others here is my 2-cents:
Keep the backlash on the small end of the specs. Maybe a differential builder can make some suggestions.
Re: Video from tonight, and some carnage Followed. [Re: ProSport] #231012
02/21/09 11:11 AM
02/21/09 11:11 AM
Las Vegas
Las Vegas
Thanks, it's a 14.5-1 compression RB 496 w/ Indy MW EZs done by Dwayne Porter he did the cam as well .630 lift Comp Roller, and Flying toilet, w/ Star Vacuum Pump, this combo has worked very awesome and is very low maintenence, Car weighs 3150 w/ me in it.
Re: Video from tonight, and some carnage Followed. [Re: Garceau] #231013
02/21/09 03:01 PM
02/21/09 03:01 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
To the purists, my Fab9 housing and Strange center section have NO ford parts! All are upgraded aftermarket for strength and reliability.
I have hundreds of 9.52-9.78 passes on the center, axles, etc. No problems! Don
Re: Video from tonight, and some carnage Followed. [Re: cudadon] #231014
02/21/09 03:07 PM
02/21/09 03:07 PM
Canada
Canada
What center section and parts are you running Don?
CrAzYMoPaRGuY
Re: Video from tonight, and some carnage Followed. [Re: cudadon] #231015
02/21/09 03:08 PM
02/21/09 03:08 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
The first pic was on Rob's table @ LRT Chassis after he put the braces and 4 link brkts. Heres one when it's ready to go in the Barracuda! You won't be sorry!
IIRC mine cost about $2000-2500 with Strange brakes. Don
Re: Video from tonight, and some carnage Followed. [Re: CrAzYMoPaRGuY] #231016
02/21/09 03:19 PM
02/21/09 03:19 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Strange aluminum center, the better pinion supp., 35 spl axles, 4.3 pro gears, the bigger bearings in the axle tubes, 5/8" studs, 1350 cm yoke. Stuff like that, and the price wasn't bad for a Fab 9, which is as strong as most of us will ever need. Don
Re: Video from tonight, and some carnage Followed. [Re: afxcoronet] #231017
02/21/09 03:32 PM
02/21/09 03:32 PM
Tucson, Arizona
johnnyrotten Offline
Tucson, Arizona
What is done to the Dana other than the pro gear and I assume a spool and axles? Caps or cover with the support? The fab nines are nice, but the Dana is tough and you should not be having problems at your ET and weight. If you sell it off PM me, I am interrested.
Re: Video from tonight, and some carnage Followed. [Re: johnnyrotten] #231018
02/21/09 05:18 PM
02/21/09 05:18 PM
iowa
bad1970dust Offline
"Hollywood"
bad1970dust  Offline
"Hollywood"
iowa
sounds like you need some one who knows to set up a dana ive got 9 years of 8 sec. abuse on my dana. car weighs 3110. has a 1.27 60 on motor and 1.20 on bottle runs 8.80 on motor 7.70 on gas.rear end has been together for 17 years in the car.not even a bearing change.find a new builder,by the the picture is on the motor no juice!!!!!
Re: Video from tonight, and some carnage Followed. [Re: bad1970dust] #231019
02/21/09 08:32 PM
02/21/09 08:32 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
is that car an 1/8mi. car? if so, why the 4.30's?
Re: Video from tonight, and some carnage Followed. [Re: johnnyrotten] #231020
02/21/09 10:28 PM
02/21/09 10:28 PM
Las Vegas
Las Vegas
Has the Strange spool, Strange Pro gears, 35 spline Moser Axles, and Moser rear cover w/ cap supports. Thank you
Re: Video from tonight, and some carnage Followed. [Re: tjmarcus1] #231021
02/21/09 10:33 PM
02/21/09 10:33 PM
Las Vegas
Las Vegas
Thanks, I'm thinking of giving it one more try w/ new builder. Your Car is Awesome, one of my favorites on here...
We run both 1/8 and 1/4 mile down here, most our bracket races are 1/8 mile, but the Divisionals and national events are 1/4. thinking of going back to the 4.56s though.
Thanks a lot guys, I hope to have the rearend and tranny out tomorrow night.
Curtis
Re: Video from tonight, and some carnage Followed. [Re: afxcoronet] #231022
02/21/09 10:41 PM
02/21/09 10:41 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
NO offense Curtis, as I say this from 30 years of racing, but, that launch is pretty tame. Something in the setup is hosed. I have raced / watched several thousand passes over the years, and find 2 ring and pinion failures with that car / Dana 60 combo REALLY SUSPECT. Go back to BASICS. Something is amiss.
Leigh
