Re: Replacing the main body on an old school Holley 830?
[Re: Jeremiah]
#2309557
05/23/17 02:53 AM
05/23/17 02:53 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I do not believetThere's aftermarket main bodies to fit the 830. I ran one for years and looked everywhere I could think of. The ones I've found that match the throttle bore are smaller in the Venturi. I believe your best option may be to buy another carb and piece it together.
[Re: Jeremiah]
#2309620
05/23/17 09:32 AM
05/23/17 09:32 AM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
They make a tool to tighten those boosters up. Its used when we changed to different boosters
JAKES AUTOMOTIVE
[Re: JAKE68]
#2309676
05/23/17 11:12 AM
05/23/17 11:12 AM
Posts: 610 long time lurker, short time p...
PorkyPig
They make a tool to tighten those boosters up. Its used when we changed to different boosters I don't believe you can retighten them if they got loose after being installed. I think it requires installing new boosters to get the proper fit. That tool isn't cheap either.
[Re: Jeremiah]
#2309715
05/23/17 12:26 PM
05/23/17 12:26 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I'd just buy a replacement hp 750 body from Holley or Proform and see how it works.
What is that in the arrow anyway??
You actually can tighten the boosters a bit with the booster install tool, provided they're not too loose. If it was a race car running race fuel, you could also JB weld where the booster comes into the Venturi........ But it just gets soft with long term exposure to ethanol.
Another even lower buck option for main body replacement is to see if you can buy a used stock Holley main body from someone who swapped theirs out for a Proform unit. Cut the choke tower off, blend it in........ Should work okay.
You could also send to a carb shop to have the boosters replaced.
Oh....... And I don't consider that an "old school" 830. That's a HP830.
The old school ones had choke towers on them...... Like number 0-9380. There was a downleg version too...... Can't recall the number though.
