how to bench test a 4 speed
#2307251
05/19/17 10:26 AM
05/19/17 10:26 AM
Posts: 1,107 Lynch Road
mro
Lynch Road
Is there anything I can do to test a 833 on the bench - other then the obvious. It's been sitting with me for at least 13 years and i would bet it hadn't been used since the late 80's or early 90's
68 Satellite Wagon and a few other ones
Re: how to bench test a 4 speed
[Re: mro]
#2307637
05/19/17 10:10 PM
05/19/17 10:10 PM
Posts: 4,798 Castlegar, BC, Canada
That AMC Guy
Might not be a bad time to change seals. Pull the side cover, look for abnormal wear. If it looks good, run it.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
[Re: mro]
#2309313
05/22/17 08:36 PM
05/22/17 08:36 PM
RapidRobert
It's been sitting with me for at least 13 years and i would bet it hadn't been used since the late 80's or early 90's Did you run it before or did you purchase it used? If it was good before it should be good now (if no rust/corrosion). I ain't a stick guy but replacing the seals sounds like a reasonable plan.
[Re: RapidRobert]
#2309414
05/22/17 11:04 PM
05/22/17 11:04 PM
Posts: 10,731 North Dakota
6PakBee
North Dakota
There is no way that I know of to functionally bench test an A833. If you have a burning desire to determine the condition, all you can do is disassemble the transmission, examine and/or evaluate the components, and go from there.
