how to bench test a 4 speed #2307251
05/19/17 10:26 AM
05/19/17 10:26 AM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
Is there anything I can do to test a 833 on the bench - other then the obvious. It's been sitting with me for at least 13 years and i would bet it hadn't been used since the late 80's or early 90's
68 Satellite Wagon and a few other ones
Re: how to bench test a 4 speed [Re: mro] #2307637
05/19/17 10:10 PM
05/19/17 10:10 PM
Castlegar, BC, Canada
That AMC Guy Offline
Might not be a bad time to change seals.
Pull the side cover, look for abnormal wear.
If it looks good, run it. drive
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
Re: how to bench test a 4 speed [Re: mro] #2307692
05/20/17 12:03 AM
05/20/17 12:03 AM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Do some bench racing with it.
Re: how to bench test a 4 speed [Re: mro] #2308740
05/21/17 09:39 PM
05/21/17 09:39 PM
Finleyville, PA
Dan R Offline
Dan R  Offline
Finleyville, PA
Maybe go thru the gears.
I just bought a used 833 too.
Re: how to bench test a 4 speed [Re: mro] #2309313
05/22/17 08:36 PM
05/22/17 08:36 PM
Did you run it before or did you purchase it used? If it was good before it should be good now (if no rust/corrosion). I ain't a stick guy but replacing the seals sounds like a reasonable plan.
Re: how to bench test a 4 speed [Re: RapidRobert] #2309414
05/22/17 11:04 PM
05/22/17 11:04 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
There is no way that I know of to functionally bench test an A833. If you have a burning desire to determine the condition, all you can do is disassemble the transmission, examine and/or evaluate the components, and go from there.
Re: how to bench test a 4 speed [Re: 6PakBee] #2309837
05/23/17 03:28 PM
05/23/17 03:28 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
Ditto on the internal visuals.
I'll add since you have the tranny on the bench, to inspect the mounting plate to the transmission and especially where the shifter fastens to the mounting plate for wear. On different occasions, I've encountered worn thread bosses resulting in the shifter loosening over time. It appears that once these threaded engagement areas become worn, it's easier for the shifter to work it's way loose making shifting less precise.
Re: how to bench test a 4 speed [Re: mro] #2309917
05/23/17 05:44 PM
05/23/17 05:44 PM
A certified culture free zone.
74RALLYE Offline
74RALLYE  Offline
I installed a 833 4sp after inspecting the internals. It looked great (to me)but after installing the trans it had an awful whine especially in 2nd gear. I ended up replacing the main shaft bearings. I couldn't tell that the bearings bad with it on the bench. You might want to try to find someone very familiar with 833s to look it over before putting it in the car.
