Page 1 of 3 1 2 3
My project just got really complicated #230916
02/21/09 12:05 AM
02/21/09 12:05 AM
Hunt Valley, Maryland
1fastrunner Offline OP
My project involves replacing my front suspension and steering components, upgrading to front disc brakes and getting my engine rebuilt. The torsion bars were the first obstacle and then the upper ball joints, but now I'm really being tested. While attempting to drop out the motor through the bottom, only the drivers side was loose. I double checked everything and soon realized that the passenger side was welded to the side frame.
Re: My project just got really complicated [Re: 1fastrunner] #230917
02/21/09 12:05 AM
02/21/09 12:05 AM
Here's another view
Re: My project just got really complicated [Re: 1fastrunner] #230918
02/21/09 12:07 AM
02/21/09 12:07 AM
Here's where the front passenger frame appears to have been repaired.
Re: My project just got really complicated [Re: 1fastrunner] #230919
02/21/09 12:08 AM
02/21/09 12:08 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
You can't catch a break can you ?
Time to get out a small grinder or cut off wheel it looks like and free it up
Re: My project just got really complicated [Re: OzHemi] #230920
02/21/09 12:11 AM
02/21/09 12:11 AM
That's what I figured, I'm not sure whether I have to remove the engine first or if I can do it with it in place. I have room, I'm just worried about all the sparks.
Re: My project just got really complicated [Re: 1fastrunner] #230921
02/21/09 12:20 AM
02/21/09 12:20 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Just tape some cardboard (or something similar) up around to cover stuff from sparks..
Just grinding it should be fine.
Re: My project just got really complicated [Re: OzHemi] #230922
02/21/09 12:29 AM
02/21/09 12:29 AM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Never seen that before.
Use sheets of tin foil or cardboard to cover up anything you don't want sparks to get on.
Re: My project just got really complicated [Re: Neil] #230923
02/21/09 12:29 AM
02/21/09 12:29 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
I can loan you some tin foil...always keep plenty around to make hats out of
Re: My project just got really complicated [Re: 1fastrunner] #230924
02/21/09 12:31 AM
02/21/09 12:31 AM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
I am guessing the car was hit on that side?
Looks like alot of piece work welding there.
Not good.
Re: My project just got really complicated [Re: NTOLERANCE] #230925
02/21/09 10:18 AM
02/21/09 10:18 AM
west palm beach, florida
modelmakerinc Offline
It looks to me like the rear k-frame mounting area of the rail is crushed up (in). Pieces/patches were then welded in.
In my opinion sparks around the engine are the least of your troubles.
If the k-frame is the same one which was hit then it may be bent(twisted) as well. you may need to look into another one.
If the damage is from rust and that was someone soulution then tha k-frame is probably ok.
You may want to look into getting a complete or partial frame rail for that side. the rail can then be spliced into the good part of the existing Rail.
Re: My project just got really complicated [Re: OzHemi] #230926
02/21/09 11:34 AM
02/21/09 11:34 AM
Keeps people from stealing your(Mopar) thoughts, right.
Re: My project just got really complicated [Re: RapidRobert] #230927
02/21/09 01:32 PM
02/21/09 01:32 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Odd repair, maybe a "window" cut into the apron to repair the actual rail. Take a look at the left rail & apron, and around the cowl/firewall/apron area for signs of distortion or repair. The buckle above the rear K mount looks suspicious to me too, as does the lack of undercoating, but I don't know '71-up B bodies that well. Welding the K to the rail indicates the mounting holes may be damaged, or the K was used to pull the rail into position and the shop neglected to finish up, but that's not the proper way to pull & square. Time to check & measure the structure. Are you rebuilding the suspension because of weird handling, or because it's worn?
Re: My project just got really complicated [Re: topside] #230928
02/21/09 01:46 PM
02/21/09 01:46 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
Just pull the engin from the top then grind the welds for the K-frame.
Re: My project just got really complicated [Re: topside] #230929
02/21/09 01:47 PM
02/21/09 01:47 PM
Mechanic Falls, Maine
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
It is probably not as bad as it looks, otherwise the K frame wouldn't have bolted in well. That's not to say the K frame was ever taken out, however.........so after it is all out, take a bunch of cross measurements underneath. If they are off it can be repaired, any good frame man could do it. It looks like a nice car, don't let someone elses past scare you!
Re: My project just got really complicated [Re: 1fastrunner] #230930
02/21/09 03:12 PM
02/21/09 03:12 PM
Ohio
tak Offline
tak  Offline
Ohio
In this photo and the one above it it appears the bottom of the repair seems to have a very square edge to it. to me it looks like a piece of angle iron has been welded, this is the area between the cross member bolts. Anybody else see this. Just seems to square at the bottom, your can see it in the picture above right beside the cross member. As long as the frame to the firewall side of the crossmember seems strait, it should be a easy fix.
Re: My project just got really complicated [Re: 1fastrunner] #230931
02/21/09 05:39 PM
02/21/09 05:39 PM
yeah,what 4Bbodies said-get on a level surface and take some measurements-plumbob frame points to floor,mark same[chalk]and measure every which way-stretching a string will also let you know if you have a serious frame problem-or pay a body shop that you trust.use a dremel with a cut off wheel and hang wet/damp rags around your spark area to grind those welds-work slow and steady so the wheels [you'll need 9 or 12/ 3 to a pack]won't bust
Re: My project just got really complicated #230932
02/21/09 08:27 PM
02/21/09 08:27 PM
Well, I know the car was hit at some point in the '70's, it also has a different door and the jamb has had some work done to it. The K frame is shot anyway, I'm getting it replaced. As far as the frame rail goes, are they available, or do I need to get one from another car? I wasn't sure I could replace that section, if I could, that would be my choice to get it back to as normal as possible. If you missed my earlier post about the K frame, here's another photo of it's condition. The more I find out about this car, the list of "issues" is already a mile long, I'm surprised I've been safe in it so far.
Re: My project just got really complicated [Re: 1fastrunner] #230933
02/21/09 08:51 PM
02/21/09 08:51 PM
Virginia, US
RTDaddy Offline
super street
RTDaddy  Offline
super street
Virginia, US
You should be able to get that with the motor in, but, if there is any sign of a "spring" in the K-frame when you unbolt it, I'd get the car to a frame machine with the K-frame in it, (measure the K-frame you remove first, as it may be bent). If you need one, there may be a couple available in this area. Good luck.
"IF YOU'RE UNDER CONTROL, YOU AIN'T GOING FAST ENOUGH."
Re: My project just got really complicated [Re: RTDaddy] #230934
02/21/09 09:25 PM
02/21/09 09:25 PM
I know I can get a different K frame, I'm asking about the right front frame rail.
Re: My project just got really complicated [Re: 1fastrunner] #230935
02/22/09 04:00 AM
02/22/09 04:00 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
What is that orange square tubing thing? Is it some sort of device you bolted to the front bumper mounts to be able to roll the car around?
Page 1 of 3 1 2 3
