1971 Satellite/RR/GTX Driveshaft Length HELP! #2308937
05/22/17 09:04 AM
05/22/17 09:04 AM
NEW JERSEY
moparfury1970 Offline OP
NEW JERSEY
Hey guys, so I need some help. For those of you who own a 71 roadrunner or satellite, do you know the length of the drive shaft? I have looked at some charts online and found 1971 Dodge Charger driveshaft lengths with my same setup. Just wanted to see if any of you would know.
Here's what I know on my car.
7290
383 CID
8.75 rear with a 727 Automatic Transmission
Swapping out the old drive shaft in my car, long story, but it needs to be done. When I measured it was 51 7/8" the center of each u joint.
Any help would be appreciated.
Re: 1971 Satellite/RR/GTX Driveshaft Length HELP! [Re: moparfury1970] #2308956
05/22/17 10:41 AM
05/22/17 10:41 AM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
Looking both models up online, I see both listed as having 115" wheelbases. So, any measurements applicable to the Charger should carry over to the Satellite.
Re: 1971 Satellite/RR/GTX Driveshaft Length HELP! [Re: moparfury1970] #2309090
05/22/17 02:28 PM
05/22/17 02:28 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Yep, match transmission and axle model
Angry white pureblood male
Re: 1971 Satellite/RR/GTX Driveshaft Length HELP! [Re: moparfury1970] #2309208
05/22/17 05:41 PM
05/22/17 05:41 PM
Ottawa, Ontario
L.R Helbling Offline
Ottawa, Ontario
All 1971 satellite based cars w/383 4 bbl and 727 auto trans have 50.68" Drive shaft lengths
Re: 1971 Satellite/RR/GTX Driveshaft Length HELP! [Re: moparfury1970] #2309318
05/22/17 08:40 PM
05/22/17 08:40 PM
NEW JERSEY
NEW JERSEY
Thank you gents!
