Transmission Crossmember Big block vs Small blk #2308579
05/21/17 04:22 PM
05/21/17 04:22 PM
KENTUCKY
69CHARGERMD Offline OP
KENTUCKY
Are they the same ?
I had a 318/904 in my 70 E body,,,,
putting in a 440/727
I bought motor mounts to address the K frame issues,,,
Is the Trans Cross member the same for both ??
Thx,
Doug wink
Re: Transmission Crossmember Big block vs Small blk [Re: 69CHARGERMD] #2308902
05/22/17 02:24 AM
05/22/17 02:24 AM
I don't know 100% for sure but I would bet that it is the same.
Re: Transmission Crossmember Big block vs Small blk [Re: 69CHARGERMD] #2308904
05/22/17 02:32 AM
05/22/17 02:32 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I got one that came out of my 440 'Cuda automatic. As for being the same , small block big block, don't know. I would check 727 vs. 904 they might be different.
Re: Transmission Crossmember Big block vs Small blk [Re: 69CHARGERMD] #2308915
05/22/17 03:11 AM
05/22/17 03:11 AM
Washington/Las Vegas
1971 Gran Coupe Offline
Here is the part application list from AMD on their replacement part.
70-74 E-Body 71-72 B-Body Torsion Bar Crossmember (71-74 Requires Modification)
1970 - 1974 Dodge Challenger
1971 - 1972 Dodge Charger
1971 - 1972 Dodge Coronet
1970 - 1974 Plymouth Barracuda
1971 Plymouth Belvedere
1971 Plymouth GTX
1971 - 1972 Plymouth Road Runner
1971 - 1972 Plymouth Satellite
Re: Transmission Crossmember Big block vs Small blk [Re: 69CHARGERMD] #2308920
05/22/17 04:38 AM
05/22/17 04:38 AM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
I did a 340/727 to 440/727 on a 73 Challenger. Trans cross member was fine.
Scott
1969 Super Bee, 383/4 speed
Re: Transmission Crossmember Big block vs Small blk [Re: 69CHARGERMD] #2309104
05/22/17 02:46 PM
05/22/17 02:46 PM
Detroit Michigan
stinger Offline
stinger  Offline
Detroit Michigan
I did a 440/727 swap on my 318/904 e body and the crossmember worked fine.
Re: Transmission Crossmember Big block vs Small blk [Re: 69CHARGERMD] #2309946
05/23/17 06:46 PM
05/23/17 06:46 PM
KENTUCKY
KENTUCKY
Thanks everyone !!! Looks like it should work !!! wink
