Re: NPT FITTING SEALANT
[Re: frank]
#2308581
05/21/17 04:25 PM
05/21/17 04:25 PM
RapidRobert
options would be to tap it out to the next size larger NPT hole/fitting or JB weld the current one in there permanently (preclean it well) or as you said another housing.
[Re: RapidRobert]
#2308585
05/21/17 04:40 PM
05/21/17 04:40 PM
Posts: 96,661 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
Are you sure it's a TAPERED pipe thread, or maybe a STRAIGHT pipe thread. Same for the fittings.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: express]
#2308952
05/22/17 10:34 AM
05/22/17 10:34 AM
Posts: 10,714 North Dakota
6PakBee
North Dakota
Thread Sealant This will work. It is NOT just TFE paste but a true anaerobic sealer. You won't be disappointed.
[Re: amxautox]
#2309017
05/22/17 01:05 PM
05/22/17 01:05 PM
Challenger 1
Cincinnati, Ohio
Are you sure it's a TAPERED pipe thread, or maybe a STRAIGHT pipe thread. Same for the fittings. This is the problem, it is not the sealer. White Teflon tape should NEVER be used around fuel systems because when you take it apart it is near impossible to clean out all the little pieces. Inverted flare fittings like on 6 pak fuel lines should never have any kind of sealer on the them, especially not teflon tape! You should use WD 40 on them that allows you to get them tight and leak free.
[Re: Sxrxrnr]
#2309131
05/22/17 03:25 PM
05/22/17 03:25 PM
dogdays
[Re: Sxrxrnr]
#2309157
05/22/17 03:59 PM
05/22/17 03:59 PM
Posts: 4,720 Moved to N.E. Tennessee
GomangoCuda
The threads on an inverted flare nut are NOT intended to seal. The flare nut simply pushes the inverted flare against it's seat. If you ever can't get it to seal then the tube is not bent properly to allow the flare to seat square or the flare is bad. Fluid should never get past the flare. If it does then fix the problem. Never depend on any kind of sealer to fix what is a mechanical problem. Thread sealer is for tapered threads.
The original poster does not say what exactly he is trying to do. If he is trying to put a tapered thread into a straight thread or a flare fitting then it likely will leak no matter what.
[Re: frank]
#2309186
05/22/17 04:53 PM
05/22/17 04:53 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
It might help to know what your trying to seal up. As stated above you might be trying to seal a straight o-ring thread hole with a pipe fitting.
[Re: frank]
#2309554
05/23/17 02:41 AM
05/23/17 02:41 AM
rowin4
I assume you have tried other fitting, The next thing I would do is use a pipe tap to chase the threads , maybe a little deeper on the tap.
[Re: rowin4]
#2309724
05/23/17 12:42 PM
05/23/17 12:42 PM
RapidRobert
I assume you have tried other fitting, The next thing I would do is use a pipe tap to chase the threads , maybe a little deeper on the tap. Ding ding ding we (may) have a winna. tapered deeper to get into some fresh threads (dont forget the sealer).
[Re: Dave Hall]
#2313438
05/30/17 10:23 AM
05/30/17 10:23 AM
6PakBee
North Dakota
The mechanical/pipe fitter guys I worked with always used BOTH TFE sealant with tape over it..... The fitters I've worked with did the same thing. Once. After that I demanded they only use the anaerobic sealers. Pipe thread sealing is one area that, IMHO, where the 'belt and suspenders' approach isn't valid.
