Shifter cable length #2308375
05/21/17 10:11 AM
05/21/17 10:11 AM
Bradenton, FL
Benforsp Offline OP
Benforsp  Offline OP
Bradenton, FL
I just picked up a pro ratchet shifter to go in an e-body and wondering if someone can tell me what length cable would work best? 3' 4' 5'?? It would go in the stock location with a 727.
Thanks!
Re: Shifter cable length [Re: Benforsp] #2308447
05/21/17 01:02 PM
05/21/17 01:02 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
I use a 5 ft in my 63 B Body. 4 ft is too short
Re: Shifter cable length [Re: Benforsp] #2308451
05/21/17 01:08 PM
05/21/17 01:08 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
of the three shifters I've had in my Duster, two front load, most recent rear load, all 5ft.
Re: Shifter cable length [Re: Benforsp] #2308495
05/21/17 01:56 PM
05/21/17 01:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use the 5' ones.. and I dont use the
heavy duty ones.. they dont make a tight
enough radius
wave
Re: Shifter cable length [Re: MR_P_BODY] #2308830
05/21/17 11:25 PM
05/21/17 11:25 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
enough radius
wave
Yep - just found that out this weekend as I had to change my heavy duty one and Jegs only had the smaller one and fit is great.
Re: Shifter cable length [Re: max_maniac] #2308839
05/21/17 11:35 PM
05/21/17 11:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
enough radius
wave
If it gets near the headers it can melt(I assume thats
what happened to yours).. but I rap 2 layers of high
temp thermo tape on it and I rap that with safety wire
to make sure it stays there.. havent had any issues
since then
wave
Re: Shifter cable length [Re: Benforsp] #2309312
05/22/17 08:32 PM
05/22/17 08:32 PM
Texas
mprhound Offline
mprhound  Offline
Texas
In my e body the 5ft was about 10" to short, ended up routing a 7ft around stuff because b&m doesn't sell a 6 foot one. Found a place out of ca "cable control inc" that makes one any length you want for the b&m shifter will hopefully get it in the car in the next few weeks
Re: Shifter cable length [Re: Benforsp] #2309384
05/22/17 10:31 PM
05/22/17 10:31 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I run my cable through a section of Aerosleave around the hot spots.... buddy worked at the airport hooked me up.
