high beam/dimmer switch location #2308744
05/21/17 09:43 PM
05/21/17 09:43 PM
Northern Tier
BCSharp Offline OP
BCSharp  Offline OP
Northern Tier
When the drivers side floor pan was replaced years ago on my 71 Charger I didn't think to measure the dimmer switch location (if that part of the pan was even intact), I was just going to wait and check where the hole in the carpet was when I installed it but wouldn't you know it the replacement carpet doesn't have a hole either, so does anyone have a measurement where the switch should be installed?
71 Charger R/T 67 Barracuda 99 Ram Sport 09 Challenger R/T
Re: high beam/dimmer switch location [Re: BCSharp] #2312658
05/28/17 11:24 PM
05/28/17 11:24 PM
Chilly Northern, Minn.
71 Charger R/T Offline
Wow! I thought I'd just go out and peel back my carpet and take a picture for you! Six screws for the sill plate and one in the kick panel later, I hopefully got what you need.......
The one measurement is from the edge of the floor pan at the side.
The other is the closest I can figure to center of the seam at the floor pan to cowl seam (under seam sealer).
Re: high beam/dimmer switch location [Re: BCSharp] #2312707
05/29/17 12:36 AM
05/29/17 12:36 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Well I'm going to say " thank you" even if he isn't...
Re: high beam/dimmer switch location [Re: Dave Hall] #2312833
05/29/17 10:27 AM
05/29/17 10:27 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
me too! that was an awesome reply to a question!
Re: high beam/dimmer switch location [Re: mikemee1331] #2313083
05/29/17 05:02 PM
05/29/17 05:02 PM
Thanks guys! I always figure a picture is worth a thousand words....... Some think of me as a man of too many words!
