A fairly good weekend
#2308727
05/21/17 09:31 PM
05/21/17 09:31 PM
dartman366
Mt. Vernon, Ohio
at the Power Classic at National trails, got nothing accomplished Friday as on and off rain ruined the day only thing I got done was wipe the car down about 4 times,,It's never been cleaner, Sat I spent my time trials going after my licence runs and got it done thanks to David Ross and John Vesley for signing off for me an Thanks for the crew @ NTR for getting it done even with the weather and the zoo they were dealing with trying to get the show on the road, did go 2 rounds in the super-pro elimimations but had to foot brake it after I developed a wiring gremlin with the transbrake and it wouldn't work (had to get out and reach under the car and jiggle the wire to even back up) but i give it my best shot and the tree bit on the second round, did get a new best 1/8 mile MPH at 109.24 and two back to back et's of 6.237 on a 6.22 dial,,,never done that before.lol
Re: A fairly good weekend
[Re: J_BODY]
#2308750
05/21/17 09:48 PM
05/21/17 09:48 PM
dartman366
Mt. Vernon, Ohio
those through the case connectors don't ever seem to be the greatest in the world. Don't know if its the connector or the wire end, will find out this week,, if it is the connector then it's the first time for me, but I have heard others say the same as you.
[Re: dartman366]
#2308823
05/21/17 11:13 PM
05/21/17 11:13 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Bill.. at least you got your license passes in and made a couple of runs.. and it came home in 1 piece EDIT My connector use to come loose and I had to squeeze my connector(outside of the case.. easy fix)
[Re: dartman366]
#2309044
05/22/17 01:40 PM
05/22/17 01:40 PM
Posts: 19,375 Las Vegas
Al_Alguire
Las Vegas
Congrats on the license run, keep after it..Oh yeah electrical gremlins suck...
[Re: MR_P_BODY]
#2309416
05/22/17 11:06 PM
05/22/17 11:06 PM
dartman366
Mt. Vernon, Ohio
Bill.. at least you got your license passes in and made a couple of runs.. and it came home in 1 piece EDIT My connector use to come loose and I had to squeeze my connector(outside of the case.. easy fix) mike I think it's the pass thru connector, you can sit there and just spin the center part around and the wire is still tight, so I made up my own with a brass fitting, wire and some JB weld, then I will solder my crimp terminals when the JB sets up.
[Re: dartman366]
#2309434
05/22/17 11:19 PM
05/22/17 11:19 PM
Posts: 1,030 ohio
67mprfan
ohio
Great talking to you glad everything went good for you
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: 67mprfan]
#2309439
05/22/17 11:23 PM
05/22/17 11:23 PM
dartman366
Mt. Vernon, Ohio
Great talking to you glad everything went good for you Thanks and it was good chatting with you also.
