Could too much clearance cause this? Too little clearance. It will not allow the piston to return far enough to uncover the inlet from the reservoir. Bleed the master cylinder off the booster. When you are done and putting it back on the booster it should sit flush on the booster without any pressure to put it there. If the pushrod is holding it out then shorten the rod.
