Source for 1/2-20 & 9/16-20 brake line caps #2308324
05/21/17 02:50 AM
05/21/17 02:50 AM
Iowa
dsp Offline OP
dsp  Offline OP
Iowa
I would like to cap off my master cylinder lines after I remove the master cylinder to rebuild it. Does anyone make 1/2-20 & 9/16-20 brake line caps?
Re: Source for 1/2-20 & 9/16-20 brake line caps [Re: dsp] #2308332
05/21/17 03:17 AM
05/21/17 03:17 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Slide the tube nuts back and put some 3/16" silicon caps on the tubing.
If that won't work for you here is a good place to start:
https://www.summitracing.com/search?Sort...Plug%20Fittings
The 9/16-20 might be tough to find being Chrysler specific.
Re: Source for 1/2-20 & 9/16-20 brake line caps [Re: Jeremiah] #2308401
05/21/17 11:27 AM
05/21/17 11:27 AM
moparx Offline
moparx  Offline
i make my own caps by using junk yard lines. just cut the line past where it comes out of the master nuts, then braze the line remnant/nut together. not sure however, if you have access to yard parts. weatherhead fittings, at one time, had adapters that went from the 1/2 & 9/16-20 thread to regular female 3/16" brake line. then all that was required was a pair of male 3/16" brake line plugs to make a cap. edelman also made these adapters. parts stores always had a couple of boxes of these [and other odd ball brake line adapters] behind the counter to help out with emergency repairs.
beer
Re: Source for 1/2-20 & 9/16-20 brake line caps [Re: dsp] #2308403
05/21/17 11:47 AM
05/21/17 11:47 AM
North East USA
BIGGERED Offline
Reasonable Title
BIGGERED  Offline
Reasonable Title
North East USA
I just looked at 4 different brass fitting supplier catalogs and it appears to not be a standard part.
Closest I have found are unions and plugs in 1/2-20 but the 9/16-20 Nuts are not cataloged. I see 9/16-18 in both 3/16 and 1/4 tube steel nuts but no unions.
I did just find an adapter from 3/16 tube 9/16-20 male to 3/16 tube 3/8-24 female.
Fairview fittings
WH-7910 Male Thread 3/16 (9/16-20) to female inverted 3/16 (3/8-24) (I'm pretty sure this is of no help)
Red
