Page 80 of 85 1 2 78 79 80 81 82 84 85
Re: paint job on a budget!? #23070
05/20/06 12:56 AM
05/20/06 12:56 AM
Anonymous OP
Anonymous OP
Can you describe the 'splotchyness'?
It looks like what happened when my air compressor started overheating when I sprayed my car a couple of years ago
its glossy on some areas, but not in others.
Re: paint job on a budget!? #23071
05/20/06 12:31 PM
05/20/06 12:31 PM
Milwaukee, Wisconsin
Forgiven Offline
Forgiven  Offline
Has anyone tried spraying the Rustoleum yet? Particularly the tintable base ("high gloss") stuff? If so, has anyone had success or problems, and what were they? Considering spraying it, but want to test the waters first...
He's the same yesterday, today, and forever! 70 Charger R/T
Re: paint job on a budget!? #23072
05/20/06 01:37 PM
05/20/06 01:37 PM
Anonymous OP
Anonymous OP
Just thought you guys would be interested in this. On the TV show Trucks! on SpikeTV, they are applying primer to one of their projects, with a roller. They are saying "applying it in a way you never thought about before". Figured I'd chime in.
Re: paint job on a budget!? #23073
05/20/06 02:13 PM
05/20/06 02:13 PM
Anonymous OP
Anonymous OP
i'm probably going to do 5 coats total, my question back to the splotchyness. When I wetsand the car, does will the splotchyness go away? I just want to get rid of that splotchyness and polish the paint. The car looks 100% better besides the splotchyness and I just want to finish the car now.
Thanks,
Nick
Re: paint job on a budget!? #23074
05/20/06 04:36 PM
05/20/06 04:36 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
any west coasters, spike tv, the show trucks. they showed a little preview of whats next. they showed ROLLING primer over a patch they just made
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: paint job on a budget!? #23075
05/20/06 06:34 PM
05/20/06 06:34 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Thanks,
Nick
Nick, I dont know if you saw it but I replied to your original question above (the 2nd post after your question).
I didn't see the show "trucks" but the roll on primer was discussed a few months ago on this very thread (dont ask me to try and find it ). there was a link to an auto body industry website describing the application process.
Re: paint job on a budget!? [Re: Exit1965] #23076
05/20/06 07:55 PM
05/20/06 07:55 PM
Anonymous OP
Anonymous OP
exit1965
so i have to repaint, wetsanding will not get rid of it?
here are some pics of my car
http://www.latech.edu/~njt002/car/paint (not 56k friendly)
Re: paint job on a budget!? #23077
05/20/06 09:17 PM
05/20/06 09:17 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
exit1965
I think wetsanding/polishing that area could make it shine, so you may want to try that first. I assume you were done with your coats? Then go head and try your final wetsanding with 2000 or so and see if you can get everything to look the same, then go ahead and polish it.
On my little test areas I did a couple months back, after the final wetsand (which I did with 1500), the surface was kind of glossy at that point. If there's existing areas of splotchyness, which means less paint got there on that layer, I think you'll end up going through that area to the layer underneath, while the glossy areas this wont be necessary and you'll be polishing a different layer for those areas. I'm not sure if it will matter in terms of how it looks..
let us know, because i am finding those here and there on my car, but I really am trying to avoid them by rolling over areas a few more times to try to get the paint to lay evenly..
Re: paint job on a budget!? #23078
05/20/06 09:29 PM
05/20/06 09:29 PM
Anonymous OP
Anonymous OP
did anybody try using a turbine sprayer to lay the paint down??
Re: paint job on a budget!? #23079
05/21/06 12:27 AM
05/21/06 12:27 AM
Anonymous OP
Anonymous OP
I'm looking at your pictures and waiting to do my integra also. I was wondering if those pictures are done with the compressor(being sprayed) or are you using the roll on method? Thanks
Re: paint job on a budget!? #23080
05/21/06 12:40 AM
05/21/06 12:40 AM
Anonymous OP
Anonymous OP
if you look in one of the pics you can see what i'm using; just a roller and a foam brush.
Re: paint job on a budget!? #23081
05/21/06 01:55 AM
05/21/06 01:55 AM
Anonymous OP
Anonymous OP
alright... i still have to paint one door handle, and take some of the paint off the side moldings, and also buff... a quick question... i bought this buffer, http://cgi.ebay.com/ws/eBayISAPI.dll?Vie...N%3AIT&rd=1, will this work, and will it bring out the shine? as of now, i really have no shine...
Re: paint job on a budget!? #23082
05/21/06 09:07 AM
05/21/06 09:07 AM
Anonymous OP
Anonymous OP
Seems like it should work. You could probably polish by hand but it would take a while. I had a 10" Ryobi but I took it back because it was too big for polishing out my rocker panels and spoiler.. I finally got the 6" yesterday and used it last night.. man, polishing really does bring out the shine. Even with all the polish residue on my test piece I can see reflections through it. I suppose I should clean it up a bit. I am going to test another polish today. It is like 5 times the cost of the Turtle Wax product
-Serp
Re: paint job on a budget!? #23083
05/21/06 09:10 AM
05/21/06 09:10 AM
Anonymous OP
Anonymous OP
I have been fixing that goofy dent and gas lid problem. I got the gas lid on thursday and just started painting. While I was fixing the dent I figured I should just fix the rest annoyances... so I fixed a rough area on the front spoiler and rear bumper and patched the two holes in the nose where the emblem goes. I am not sure what those were for but when I put the new emblem I could see part of the hole..
Anyway, what is the difference between the terry bonnet and the wool one? I wasnt sure which one to use when I polished so I used the terry bonnet and it seems to be working good. Is the wool one for metals or something?
Oh and started painting my black metal trim with gloss black.. very nice paint it comes out very smooth and shiny
Thanks,
-Serp
Re: paint job on a budget!? #23084
05/21/06 10:48 AM
05/21/06 10:48 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I remember reading in here somewhere to use a soft foam pad.
So do you like that Ryobi 6 inch polisher? thats the one I was thinknig of getting..
Re: paint job on a budget!? [Re: Exit1965] #23085
05/21/06 01:52 PM
05/21/06 01:52 PM
Col. Ohio
The Avg. Valiant Offline
Col. Ohio
I was watching trucks or musclecar or one of those, and they said something about that roller primer. Anyone know anything about that? What its called, where to get it?
Jacob
Re: paint job on a budget!? [Re: Exit1965] #23086
05/21/06 02:28 PM
05/21/06 02:28 PM
Anonymous OP
Anonymous OP
I'm painting my car high gloss black. The areas that i wet sanded came out nice and smooth, but they turned very light grey. I used 800 grit for wetsanding if that matters.
I have tried two different wax nu2000, turtle wax with color guard and they didnt work. I just went to the store and got some of the recommended turtle wax and some turtle wax polishing compound. I'm currently trying those two and I will post the results. I dont understand why I cant get that gloss black look back after wetsanding.
I hope I can get the shine back.
Re: paint job on a budget!? #23087
05/21/06 02:35 PM
05/21/06 02:35 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
To anyone who's painting flexible bumpers, etc, does the paint seem to be holding up pretty well? I've decided I need to tackle my Daytona first, and it's got flexible bumpers front and rear, as well as some lower body cladding that's made of the same stuff. I'll eventually sell this car, but I dont' want to complicate life for the next owner...
Clair
Re: paint job on a budget!? #23088
05/21/06 03:19 PM
05/21/06 03:19 PM
Anonymous OP
Anonymous OP
Did you do a final sand with 2000gt? If your surface is looking grey it is probably because of scratches in the surface. I think 800gt is too coarse. Using an electric polisher works great. However, even with the Turtle Wax POLISHING COMPOUND it takes time. Once you finish with the polishing compound you should come to a nice smooth surface.. then you could follow up with a wax. I am not sure if the paint is the problem because others have been successful.
Cheers,
-Serp
Re: paint job on a budget!? [Re: Clair_Davis] #23089
05/21/06 03:22 PM
05/21/06 03:22 PM
Anonymous OP
Anonymous OP
Clair
Yar my rear bumper is one big flexable, thin shell. The paint seems to adhere with no signs of difficulty.
