5.9 mag with carb and AC
#2306423
05/18/17 12:43 AM
05/18/17 12:43 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I have a 5.9 with chinese dual pattern intake. The water neck is in the way of AC compressor. I thought I could cut the right rear lug off the compressor but a hole opened up.
Anyone have a solution?
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: 5.9 mag with carb and AC
[Re: sixpackgut]
#2306450
05/18/17 01:36 AM
05/18/17 01:36 AM
sixpackgut
Charleston
I dont know if a swivel housing would even help.
[Re: sixpackgut]
#2306468
05/18/17 02:02 AM
05/18/17 02:02 AM
RapidRobert
it'd take a bit of fabbing but what about shifting the compressor over a bit?
[Re: RapidRobert]
#2306486
05/18/17 02:35 AM
05/18/17 02:35 AM
sixpackgut
Charleston
it'd take a bit of fabbing but what about shifting the compressor over a bit? I steel plate. Thats an idea
[Re: sixpackgut]
#2306704
05/18/17 01:37 PM
05/18/17 01:37 PM
Posts: 1,822 Colorado
denfireguy
Colorado
Had the clearance issue with an Edelbrock LD4B and the VIntage Air bracket for a Sanden Compressor. Solved it with an Edelbrock Performer intake that had the thermostat housing more offset to the driver side. Cleared, just barely, but cleared. Downside is the LD4B is a much better intake. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: sixpackgut]
#2306720
05/18/17 01:56 PM
05/18/17 01:56 PM
Posts: 15,552 Norwich CT USA
moparts
Norwich CT USA
The Magnum Edelbrock Intake and the now discontinued Mopar intake have the filler neck in the correct location on the passenger side
The cheap intakes do not
Tom ,
2011 Ram 3500 C&C Diesel 2009 Challenger R/T 1971 Challenger Conv. 511/4 speed 1970 Challenger R/T 503/727
[Re: kenworth_goose]
#2307131
05/19/17 12:17 AM
05/19/17 12:17 AM
Posts: 2,735 541 slobovia
A990
541 slobovia
You could take a factory magnum thermostat housing and re-angle the housing to lean away from the compressor. This right here. The angle is very slight but noticeable. New ones are cheap at the part stores. If going used, check for pitting on the mating surfaces.
[Re: sixpackgut]
#2307200
05/19/17 03:43 AM
05/19/17 03:43 AM
sixpackgut
Charleston
Ill look at that but Im leaning on getting an edelbrock intake and selling this one. Piss me off
