Page 3 of 10 1 2 3 4 5 9 10
Re: 383 HP 330vs335 hp [Re: NachoRT74] #2306226
05/17/17 06:42 PM
05/17/17 06:42 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
Specs are
383 2V, 330HP 4V, and 350HP 440
256°/260° .425"/.435"
335HP 383, and 475HP 440
268°/284° .450"/.458"
Re: 383 HP 330vs335 hp [Re: NachoRT74] #2306233
05/17/17 06:54 PM
05/17/17 06:54 PM
Valencia, España
NachoRT74 Online content OP
NachoRT74  Online Content OP
Valencia, España
Ok, pics of my 74 catalog and DC book
This "prooves" the basic of the Purple shafts is the highest of the production shafts.
Last file is on the DC section talking about the upgrade suggestions
Re: 383 HP 330vs335 hp [Re: NachoRT74] #2306241
05/17/17 07:05 PM
05/17/17 07:05 PM
NY,USA
Bad B-rad Offline
Bad B-rad  Offline
NY,USA
Now That is some VERY helpful info!!!!!!
I will be saving all of those screen shots!!
So it looks as if I may be yanking out my cam and getting a "roadrunner/magnum" cam.
I only wish I could see dyno numbers from 1000rpm-6100rpm on the two different cams(335 vs 330) Just to see how much low numbers you give up switching the two.
Any body have a 330 hp 383 and put in a 335 cam, if so how differently is the car to drive?
Thanks for the above info!!!!!
Re: 383 HP 330vs335 hp [Re: NachoRT74] #2306251
05/17/17 07:21 PM
05/17/17 07:21 PM
Valencia, España
Valencia, España
Now I'm noticing a debate never thought it was to come and it is about the HP exhaust manifolds... which I think is CLEAR all magnum engines were with them.
My main concern is it seems the 335 hp 383 is MORE MAGNUM than the other LOL.
And per the mopar parts catalog, the 400 magnum got the same camshaft than the 383 335 engine, being a lower performance engine
Re: 383 HP 330vs335 hp [Re: NachoRT74] #2306272
05/17/17 07:45 PM
05/17/17 07:45 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
'68 Dodge Specs:
Re: 383 HP 330vs335 hp [Re: NachoRT74] #2306297
05/17/17 08:41 PM
05/17/17 08:41 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Originally Posted By NachoRT74
[quote=BSB67]
then there is a superseded number for it, 4071002 camshaft one of them I have it NOS on its original box, and is purple.
I vaguely recall that number, it was a newer "smog" cam, same lift and duration but altered timing events.
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: 383 HP 330vs335 hp [Re: NachoRT74] #2306317
05/17/17 09:10 PM
05/17/17 09:10 PM
Valencia, España
Valencia, España
Not per DC book.
Re: 383 HP 330vs335 hp [Re: 375inStroke] #2306344
05/17/17 10:15 PM
05/17/17 10:15 PM
Valencia, España
Valencia, España
Originally Posted By 375inStroke
Specs are
I missed this post!
Thats sounds like the dealer databooks says, but DC book seems to be slightly contradictory
So, any 383 4V is a magnum still with standard cam and springs, and all got HiPo exhaust manifolds. But the 335HP is a magnum "plus"
And any 400 4V is also a magnum BUT they got all the "high lift" cam, still with the lower compression rate. LOL
Re: 383 HP 330vs335 hp [Re: NachoRT74] #2306352
05/17/17 10:31 PM
05/17/17 10:31 PM
NY,USA
Bad B-rad Offline
Bad B-rad  Offline
NY,USA
Well that goes back to what I was told years ago that the 383"magnum" was born by putting the same heads on it as the 440. So by that thinking any 4bbl 383 from 68-71 is a Magnum. So is it just a "Magnum" when the 383/400/440 share heads? Like pre 68 383's had there own head,a 67 383 had its own head,67 440 had it's own head.
And I just wanted to know if Dodge called my 69 383 4bbl/duel exhaust 330hp engine a 383 Magnum or 383 4bbl for my air cleaner!!!LOL
But I love learning Mopar stuff!!!
Re: 383 HP 330vs335 hp [Re: Bad B-rad] #2306370
05/17/17 10:56 PM
05/17/17 10:56 PM
NY,USA
Bad B-rad Offline
Bad B-rad  Offline
NY,USA
Well just going by the 1969 Charger sales book, the only engine that has the title MAGNUM attached to it at all is the 440.
So as far as Dodge was concerned I guess its a 383 2Bbl or 383 4Bbl, and the R/T 's 440 MAGNUM.
I thought that if you had a non A/C 383 4Bbl in a Charger it was a Magnum, but going by the 69 sales book nope, never. Only 383 4Bbl was the 330HP one, in a Charger in 69.
And it looks as if (at least the photo in the sales book) duel snorkel, no pie tin.
Re: 383 HP 330vs335 hp [Re: NachoRT74] #2306384
05/17/17 11:27 PM
05/17/17 11:27 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
the reason for this pissing match is the original question is not specific enough to answer the question properly
This urine spraying match comes up about once every year, never gets settled.
Re: 383 HP 330vs335 hp [Re: NachoRT74] #2306511
05/18/17 03:33 AM
05/18/17 03:33 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Specs are
No.
The 383-4 335 horse was introduced in 68 with the Road Runner. The difference between it and the 330 horse assembly was, basically, it used the higher lift cam and springs introduced the year before in the GTX and Coronet R/T. The carb was different than the 330 horse as well as the 335 was intended to get a windage tray.
The 906 heads were used on all 68 big blocks. The springs were different with the 335 but not the head casting.
As Dan stated earlier, there are no HP exhaust manifolds. There are two and 4bbl manifolds.
When Dodge brought out the Super Bee mid year, they used the 335 horse assembly and called it the Magnum.
The 335 horse variant of the 383-4 was used from 68-70. The applications changed each year. In 68 only the RR and SB without A/C got the 335 assembly.
In 69, any B body with manual transmission without A/C and the RR or SB with either transmission and without A/C got the 335 horse version. Any 69 B body with A/C got the 330 horse. Any non RR or SB B body (Charger, Satellite, Coronet) with automatic transmission got the 330 horse.
The 1970 applications get a little more convoluted with the use of the 335 horse in B and E bodies. However, there was a 335 horse assembly available with A/C in 1970.
Properly and originally, the term 383 Magnum refers to a 68-70 Dodge with the 335 horse version. Dodge did use the term Magnum on other engines after 1970.
So....
1968: 383 Magnum in Super Bees without A/C.
1969: Manual transmission B bodies without A/C OR a Super Bee with either transmission and without A/C. So no 69 Charger with A/C or automatic would have the 335 horse Magnum.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: 383 HP 330vs335 hp [Re: NachoRT74] #2306516
05/18/17 03:52 AM
05/18/17 03:52 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Magnum is a Dodge term on some engines. Super Commando is a Plymouth term.
Re: 383 HP 330vs335 hp [Re: NachoRT74] #2306587
05/18/17 11:02 AM
05/18/17 11:02 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Wow so much bad information
Re: 383 HP 330vs335 hp [Re: 69CoronetRT] #2306687
05/18/17 01:24 PM
05/18/17 01:24 PM
Hamburg - Germany
SuperRob Offline
SuperRob  Offline
Hamburg - Germany
Originally Posted By 69CoronetRT
The 383-4 335 horse was introduced in 68 with the Road Runner. The difference between ...
Thank you!
Re: 383 HP 330vs335 hp [Re: NachoRT74] #2306837
05/18/17 04:32 PM
05/18/17 04:32 PM
NY,USA
Bad B-rad Offline
Bad B-rad  Offline
NY,USA
I think that if what was said above is true, about the exhaust manifolds, that there is a 2bbl and 4 bbl and there is no HP exhaust manifolds,that has also helped fuel the confusion.
Because everyone says the HP exhaust manifolds were only on HI-Po engines(AKA MAGNUM/ROADRUNNER) And my 69 charger 383(blue 330hp) 4bbl with A/C has duel exhaust and the four barrel exhaust manifolds.
So by seeing the four barrel exhaust manifolds and everyone calling them HP manifolds you would think that I have the HP engine (AKA MAGNUM) when it is really the 330 hp version.
and I would guess that unless you can hear the two engines side by side to hear the different cam shafts(if you can even hear a difference)that you could paint a blue engine orange and slap on the pie tin and then confuse the hell out of everyone!LOL
So I bet the exhaust manifolds added to the issue we are talking about.
Re: 383 HP 330vs335 hp [Re: 69CoronetRT] #2306942
05/18/17 07:23 PM
05/18/17 07:23 PM
Khemi, Stygia
Mebsuta Offline
Mebsuta  Offline
Khemi, Stygia
I agree.
68 Roadrunner. 383 4-spd. Beat up.
Re: 383 HP 330vs335 hp [Re: Bad B-rad] #2306978
05/18/17 08:29 PM
05/18/17 08:29 PM
Milano, Italia
FK5 Offline
FK5  Offline
Milano, Italia
Originally Posted By Bad B-rad
My 69 383 4bbl A/C car has duel exhaust,with what looks to be factory "H" pipe and hangers and mufflers.
And I now think I figured out the yellow crayon 68 written on the front of my pass side valve cover is not a 68 it is an 899 and one 9 is gone and its written upside down.
I will now have to go see if the pipes and mufflers have any numbers on them so I can figure out this semi-mystery!!!
Also do 383HP MAGNUM ROAD RUNNER 335Horse engines use the same pistons as 383 330horse pistons, or do the 335horse motors have valve pockets in them?
Could you put a "RoadRunner/Magnum" cam in the 330hp 383 with 2bbl cam with out causing any damage? I know my engine(330horse) the pistons almost have a positive deck height at TDC.
These guys are probably more knowledgable than me, but I don't think there is such a thing as a "factory H-pipe." Just FYI since you are talking about swapping a cam nobody will ever see for originality...
Re: 383 HP 330vs335 hp [Re: NachoRT74] #2307115
05/18/17 11:54 PM
05/18/17 11:54 PM
Valencia, España
Valencia, España
After all these years is hard to find an all original Mopar from fact, but looikng at this, maybe...
http://bringatrailer.com/2014/03/20/all-original-driver-1968-dodge-charger-383/
Magnum engine? Mmm
Re: 383 HP 330vs335 hp [Re: NachoRT74] #2307122
05/19/17 12:07 AM
05/19/17 12:07 AM
Valencia, España
Valencia, España
Another Charger with 383... Magnum?
https://youtu.be/eApCxdPxLmw
Sellers says is matching numbers and original miles engine. Driver side manifold seems to be HiPo one.
