Page 2 of 10 1 2 3 4 9 10
Re: 383 HP 330vs335 hp [Re: MikeN] #2305894
05/17/17 04:47 AM
05/17/17 04:47 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
the reason for this pissing match is the original question is not specific enough to answer the question properly
WHAT YEAR & BODY 383 4bbl VS. 383HP 4bbl are "WE" discussing?
1970?
383 4bbl 330hp blue engine w/CARTER carb (B, C & E-bodies)
VS.
383HP 4bbl 335hp orange engine w/HOLLEY carb (B & E-bodies) ZERO C-bodies
what specifically would you like to discuss ??
Re: 383 HP 330vs335 hp [Re: NANKET] #2305898
05/17/17 05:29 AM
05/17/17 05:29 AM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
The 346 castings were also used on 440's.
Re: 383 HP 330vs335 hp [Re: 6bblgt] #2305909
05/17/17 08:31 AM
05/17/17 08:31 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
1970?
VS.
Like Dan says. Give him some specifics and he can answer most questions. I've never known him to get anything wrong as far as I far as my knowledge goes. I do have a 70 Challenger 383 SE with the blue 330 horse ( not the RT or HP). It has air and a Carter carb. It has no windage tray, a 402 pan, and hp manifolds. My original 70 Cuda with the orange 335 HP Version had a Holley and hp manifolds.
Re: 383 HP 330vs335 hp [Re: NachoRT74] #2305931
05/17/17 09:51 AM
05/17/17 09:51 AM
Valencia, España
NachoRT74 Online content OP
NachoRT74  Online Content OP
Valencia, España
Yes, I just detailed 68 and 69 ( as an example ) dealer datasheet specs and compared the info between chargers and superbees, and states Chargers got the standard camshaft and superbees got the hight lift ones, along with the diff springs of course
Never thought a 383 magnum charger ( and I guess coronets and Belvederes with supercomandos ) engine got standard camshafts! I always thought all BB magnums got same performance camshafts and sorings, so the same than 440 mkaing the "Magnum" name more standard to all BB meaning same inner parts for everyone. And superbees/RR got a even "higher step" one.
What are the difference between the standard and the "high lifft" camshafts then ?
I guess the first one of the purpleshaft cams is to the 440s and superbees/RR 383s then
Wondering now about the 400 magnums camshafts too
Re: 383 HP 330vs335 hp [Re: NachoRT74] #2305941
05/17/17 10:26 AM
05/17/17 10:26 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
The lift is not that different, like 0.020" more. I have the numbers, just to lazy to go get them. The duration is bigger as well, and the real reason for the performance increase.
None of the "purple shafts" were installed by the factory. The original purples shaft/shafts were a step up or more from what was installed from the factory in wedge motors. I guess now you can purchase a resto cam from MP. Maybe it is called a purple cam too.
Re: 383 HP 330vs335 hp [Re: NachoRT74] #2305970
05/17/17 11:35 AM
05/17/17 11:35 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The difference?
One is orange the other isn't.
One has a fancy pie plate the other doesn't.
One it said to be 335hp by Chrysler, the other isn't, and this is the point. I'm sure both made their rated HP at some RPM level, but that doesn't mean it's max or that they really are that different in output.
Don't be the exception.
Re: 383 HP 330vs335 hp [Re: Supercuda] #2306113
05/17/17 02:51 PM
05/17/17 02:51 PM
NY,USA
Bad B-rad Offline
Bad B-rad  Offline
NY,USA
This is my first post here, I had almost this exact question on another site.
SO I have a 69 Charger 383 4bbl A/C 330HP car.
My car is a #'s matching car that is low miles (7,000) and mostly org shape.
It came to me with #'s matching 383 4bbl(Holley)carb, A/C(330HP) engine painted blue(turquoise) and a duel snorkel air cleaner.
It had no pie tin.
My question would be what pie tin should I have,383 4bbl,or 383 Magnum? and do I have the correct air cleaner?
Most 69 383 4bbl A/C cars I have looked up, have the duel snorkel, but I have also come across ever possible combo of color engine and air cleaner and pie tins you could imagine.
SO what is factory correct?
Also what makes the 383 330hp vs the 383 335HP?
I was told it was just the cam, that 383 A/C (330hp) engines uses the cam as the 383 2bbl engine.And the 335hp engine uses the R.R./magnum cam.(just what I was told, I do not know this as fact,just what was told to me)
Could it be the carb?(A/C has Holley vs non air Carter?)
I also would love to know what makes the 5 hp difference between the motors.? And what tin my car should have on it?
Thanks, hope to learn the thing that make the motors different.
Re: 383 HP 330vs335 hp [Re: Bad B-rad] #2306118
05/17/17 03:00 PM
05/17/17 03:00 PM
NY,USA
Bad B-rad Offline
Bad B-rad  Offline
NY,USA
I was also told,a while back, that all 4bbl Big block engines in 2nd gen Chargers, were Magnum engines, no matter the color it is painted. Because it was Dodge's performance engine in its performance car, and all A/C car engines were blue,but in a Charger it was called a Magnum.
Again I do not know that to be a fact, I am not trying to argue with anyone, I am just saying what I was told years ago by some guys, I am just trying to educate myself on the matter.
I mean you can't even feel a 5 hp difference in a 330hp vs 335hp 383 anyway, and I think the HP and torque #'s are rated at same rpm on the motors.
Re: 383 HP 330vs335 hp [Re: Bad B-rad] #2306173
05/17/17 04:49 PM
05/17/17 04:49 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Now we're getting somewhere .....
HP manifolds is a misnomer - per CHRYLER they are "DUAL EXHAUST MANIFOLDS"
All HP engines have dual exhaust, all dual exhaust car do NOT have HP engines.
Re: 383 HP 330vs335 hp [Re: 6bblgt] #2306178
05/17/17 04:54 PM
05/17/17 04:54 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
1968 B-body
the only 383HP 4bbl 335hp engines were installed in Road Runners and Super Bees
these engines included the 440HP's cam/valve springs/windage tray
(the Charger & other b-bodies 383 4bbl 330hp had the same cam as the 383 2bbl)
Re: 383 HP 330vs335 hp [Re: 6bblgt] #2306179
05/17/17 04:57 PM
05/17/17 04:57 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
fantasy "pie tins" have existed for decades
every car did not receive one & they were not available for every engine
Re: 383 HP 330vs335 hp [Re: 6bblgt] #2306182
05/17/17 04:59 PM
05/17/17 04:59 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
the 1970 Charger was the first year that all of the 383 4bbl engines used were of the "383 MAGNUM" variety (383HP)
Re: 383 HP 330vs335 hp [Re: 6bblgt] #2306194
05/17/17 05:40 PM
05/17/17 05:40 PM
NY,USA
Bad B-rad Offline
Bad B-rad  Offline
NY,USA
So it is safe to say, in my case because my car is so complete and missing only the org rims(but I got org wheel covers)and it had 70' front seats,and everything else that my car did not have a pie tin on it.
Again I am just basing that on the fact I have most every part for my car,even the jack and lug wrench, and the org carb and air cleaner are there, and that you have said not all cars had pie tins.
Re: 383 HP 330vs335 hp [Re: Bad B-rad] #2306195
05/17/17 05:45 PM
05/17/17 05:45 PM
NY,USA
Bad B-rad Offline
Bad B-rad  Offline
NY,USA
So Dan, what you are saying is that the exhaust manifolds that everyone calls HP manifolds are called Duel Exhaust manifolds by Chrysler?
SO any engine with those manifolds IS a HP(MAGNUM) Engine?
And that would mean that no 69 Chargers with 383 4bbl A/C engines had the "Duel Exhaust"(HP)Manifolds?
Re: 383 HP 330vs335 hp [Re: Bad B-rad] #2306209
05/17/17 06:20 PM
05/17/17 06:20 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
It had no pie tin.
Might be wrong but the only 383 engine that used a Holly was the 70 all the others AFB-AVS. 2 cams low performance and high performance + 6 barrel type, same specs just different lobe angle. Each engine each year shared the same head just springs where different, (67 had different ex valve size LP to HP) Chrysler did some stupid things but they did keep it simple on this stuff. Way to many 383 Hemi six-packs out there.
Re: 383 HP 330vs335 hp [Re: BSB67] #2306215
05/17/17 06:26 PM
05/17/17 06:26 PM
Valencia, España
Valencia, España
Damn! sometimes I forgett I have the direct conection performance book!!
Actually my 74 Mopar parts catalog matches the number posted there for the HiPo camshaft, 3512907 camshaft... used on all 383/400 HP and 440 HP, but this means the 335 383 or 330 383 ? so the 330 383 is not an HP still being a magnum ?
then there is a superseded number for it, 4071002 camshaft one of them I have it NOS on its original box, and is purple.
now... does that number takes to the MP 4452783 ?
then read it better on some other section and the 335 383 camshaft takes the stock 3512907... which by the direct conection book is 268-284 camsshaft with 450 lift... that meets the MP 4452783 spec and the fact the higher camshaft used from factory is a purple one
but still on the previous section talking about stock assemblies, is not clear what is considered a 383 HP to take one or the other being the 330 or the 335 engine.
pics of books later
Re: 383 HP 330vs335 hp [Re: Bad B-rad] #2306217
05/17/17 06:31 PM
05/17/17 06:31 PM
NY,USA
Bad B-rad Offline
Bad B-rad  Offline
NY,USA
My 69 383 4bbl A/C car has duel exhaust,with what looks to be factory "H" pipe and hangers and mufflers.
And I now think I figured out the yellow crayon 68 written on the front of my pass side valve cover is not a 68 it is an 899 and one 9 is gone and its written upside down.
I will now have to go see if the pipes and mufflers have any numbers on them so I can figure out this semi-mystery!!!
Also do 383HP MAGNUM ROAD RUNNER 335Horse engines use the same pistons as 383 330horse pistons, or do the 335horse motors have valve pockets in them?
Could you put a "RoadRunner/Magnum" cam in the 330hp 383 with 2bbl cam with out causing any damage? I know my engine(330horse) the pistons almost have a positive deck height at TDC.
Re: 383 HP 330vs335 hp [Re: Bad B-rad] #2306220
05/17/17 06:34 PM
05/17/17 06:34 PM
Valencia, España
Valencia, España
well the color change on Magnums is a 69/71 setup, but we had pre 68 engines being magnum and turqoise, same as post 72 being corporated blue... no matter if A/C or not. Thats doesn't eliminate the magnum spec ( or supercommando on plymouths )
Re: 383 HP 330vs335 hp [Re: NachoRT74] #2306223
05/17/17 06:37 PM
05/17/17 06:37 PM
Valencia, España
Valencia, España
ok, this is an oooold file I have had saved and forgott about it untill now, but really dunno how to read everyone of these specs. I think we can find some conclusions here
Re: 383 HP 330vs335 hp [Re: cudaman1969] #2306225
05/17/17 06:41 PM
05/17/17 06:41 PM
NY,USA
Bad B-rad Offline
Bad B-rad  Offline
NY,USA
[CUDAMAN [/quote]
Might be wrong but the only 383 engine that used a Holly was the 70 all the others AFB-AVS. 2 cams low performance and high performance + 6 barrel type, same specs just different lobe angle. Each engine each year shared the same head just springs where different, (67 had different ex valve size LP to HP) Chrysler did some stupid things but they did keep it simple on this stuff. Way to many 383 Hemi six-packs out there.[/quote]
No,I looked up the numbers on my Holley in the little white numbers books I have and it comes back as a 69 383 4bbl(with a note 570cfm).
I THINK that big block cars with air used the Holley carbs.
Because most every 69 383 w A/C I have looked at had duel snorkel air cleaner and Holley carb. So my car DID org have a Holley, but WHY it did, I do not know I can only guess, the above reason.
