jeep cherokee 4.0 #2305829
05/17/17 01:07 AM
05/17/17 01:07 AM
South-east Mn
blaze Offline OP
blaze  Offline OP
South-east Mn
I found a 2001 Jeep Grand Cherokee with a bad engine. I have a '99 Jeep Cherokee Classic with a good engine. Are the 4.0 engines (electronics) computer connections going to be the same between '99 and '01? I need this to be plug-n-play. I don't want to spend a lot of time on it....it's work beater, Thank-you
Re: jeep cherokee 4.0 [Re: blaze] #2306418
05/18/17 12:27 AM
05/18/17 12:27 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I think you are good to go, if not I believe everything will swap over from one to the other.
68 Barracuda Formula S 340
Re: jeep cherokee 4.0 [Re: Bad340fish] #2307023
05/18/17 09:55 PM
05/18/17 09:55 PM
South-east Mn
blaze Offline OP
blaze  Offline OP
South-east Mn
Thank you
Re: jeep cherokee 4.0 [Re: blaze] #2307181
05/19/17 02:26 AM
05/19/17 02:26 AM
Phoenix, AZ
Belvedere1 Offline
Belvedere1  Offline
Phoenix, AZ
My guess is no. I think 2000 was the first year for distributor-less ignition, so the 99 would have a different PCM. I could be wrong but worth researching.
