Re: Holley Ultra Xp- a " heads up " .
[Re: RustyM]
#2305328
05/16/17 02:34 AM
05/16/17 02:34 AM
Posts: 566 Texas
RustyM
Texas
[Re: RustyM]
#2305451
05/16/17 12:33 PM
05/16/17 12:33 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Rusty has pm'd me a more detailed chronicle of how the dyno session progressed and where they ended up for jetting...... At which point I told him there was likely an issue with the carb.
He made some calls to see what he could find out, and from what I understand, it was revealed that this isn't an isolated incident with these carbs.
I guess the best thing to be done here is, take this as a word of caution. If it seems the carb is unresponsive to jet changes, or requires oddball stagger jetting, or if there is any looseness to the boosters...... It probably needs to be sent back.
[Re: RustyM]
#2305476
05/16/17 01:40 PM
05/16/17 01:40 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Really disappointing. Especially with a carb that is touted as their top-dog 4150. I'd send it back for sure, and have a conversation with someone at Holley. Big company likely with people on an assembly line that don't give a sh!t about their job.... sad. I recently purchased an HP 1000 annular direct from Holley. It has worked great out of the box with only idle mixture adjustments and a main-jet adjustment.
[Re: RustyM]
#2305483
05/16/17 02:04 PM
05/16/17 02:04 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
To be fair, The 1,000 cfm HP carb I bought 20+ years ago worked really good out of the box. The 670 Truck avenger, I bought about 8 years ago, and the most recent Holley I bought (new) was the 770 cfm Ultra street avenger about 5 years ago. It checked out OK (no debris in the passages.) In my case, both avenger carbs had very lean idle circuits that needed to be have the idle restriction enlarged. Other than the QF-1000 E-85 carb on the Charger, everything else has been getting converted to EFI.
[Re: RustyM]
#2305578
05/16/17 05:21 PM
05/16/17 05:21 PM
fast68plymouth
So. Burlington, Vt.
Last item on the long list of features for this carb on the Holley website: 100% wet-flow tested by Holley technicians to assure it arrives ready to run! I guess it depends on how you interpret that statement....... I mean........ It did "run".
[Re: RustyM]
#2305641
05/16/17 07:34 PM
05/16/17 07:34 PM
fast68plymouth
So. Burlington, Vt.
Here's a "wet flowed" story...... Not from Holley though.
This was 20 years ago. Customer buys a $1400(in 1997) BG "pro stock" prepared dominator for his 540bbc.
Makes pretty good power, but is wicked lean, and is pretty unresponsive to jet changes, especially on the rear.
Put one of my carbs on, plenty rich enough, makes less power...... But it's a 1050 instead of 1150.
Try swapping rear metering block from my carb to new one...... Marginally more fuel flow, a little less power.
Try another reworked 1150, plenty rich enough...... Less power.
Several calls to BG...... We're told the dyno is reading fuel flow wrong....... Can't be the carb, it's custom built and wet flow tested.
So, we're second guessing ourselves a bit. Afterall, the new carb did make good power.
Well, before we got it figured out, it burns up 3 pistons.
I guess the dyno wasn't lying about the fuel flow.
I pull carb all apart....... One of the rear booster stake tubes had gotten the end of it folded over when it was installed, so that barrel had basically zero fuel flow.
There was a pretty long pause on the other end of the phone line when we told them what we found, and what had happened as a result.
Never did get a good explanation as to how that wasnt caught during the wet flow testing.
[Re: RustyM]
#2305697
05/16/17 09:24 PM
05/16/17 09:24 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
Ultra Xp 950 e85 out of box it was perfect! No complaints except $$$$$$
Have a great day Iowan
"obsolete is neat"
[Re: RustyM]
#2305708
05/16/17 09:40 PM
05/16/17 09:40 PM
crabman173
crabman173
Carbs are like girls they all look good when new--but it takes a test drive to determine if it is going to work out-- Over the years had some really great ones and some real trouble ( carbs and girls) I sent a set of new six pack carbs out for the money no object build before dropping them on a new big inch custom--fired it up on the dyno--sounded awful--just could not figure what was happening first couple minutes then dyno ran out of fuel--turns out there were NO jets in the carbs ( all three were set up for jets) and all that fuel was in the crankcase-- But then bought an AED 750 HO out of the box changed jetting one time and bracket raced it for many years --won a lot of rounds never ever touched it so...
[Re: RustyM]
#2305739
05/16/17 10:16 PM
05/16/17 10:16 PM
fast68plymouth
So. Burlington, Vt.
wet flow story #2......
We were a BG WD........they had a pretty good program for dealers to be able to match Summit and Jegs on the price of their carbs, which we just couldn't do with Holleys at that time.
The King Demons are introduced........and I have to have one. This is probably a couple years after the pro stock carb fiasco. I buy a 1090 non-removable sleeve version.
We have another, milder 540bbc on the dyno and I'm anxious to try it out. The engine owner is fine with it. He had just bought a new HP1250 dominator, which is kinda rich, so we jet it down and get it sorted out. I had gone through another 1050 for someone else, just wanted to make sure it was good to go....... bolt it on, make a pull......all good. Both of those carbs run just fine. Start good, idle good, decent throttle response, good fuel curve.
Bolt the new king demon on.......doesn't start great......and after its running, and the floats are set.......start messing with the mixture screws.....one doesn't seem to do anything. The motor just hunts around at idle. Throttle response is poor. I try and make a half pull.........carb is way lean.....abort the run. I just take it off.
Take carb apart......there is a machining defect at the top of one of the metering blocks where the idle tube is pressed in.......and there's a bunch of clear epoxy all over it. Needless to say I'm not impressed. I remove the idle tube only to find that a bunch of the epoxy ran down in where the fuel flows and plugged it up. Well, that explains the non-working mixture screw.
Since I had aldready been "schooled" on the booster stake tube thing...... I investgate that only to discover that one of them is folded over almost as bad as the one in the pro stock carb, and another one is slightly deformed so it's about 1/2 blocked.
Call BG, they say send it back. I say......no thanks.......just send me a new metering block and a set of stake tubes and I'll fix it myself......... which I did.........and then it worked "okay".
I got it to where it did everything well enough, but no better than an old school 1050 Holley I had.......so I sold it to a guy with an 800hp BBF.
