Re: frozen spark plug
[Re: Sxrxrnr]
#2305162
05/15/17 09:39 PM
05/15/17 09:39 PM
RapidRobert
What Stump said, & I would oil it every day for several days then get after it. You NEED it to come out in one piece.
[Re: 360view]
#2305469
05/16/17 01:26 PM
05/16/17 01:26 PM
RapidRobert
Warm the cylinder head with two large electric soldering irons like plumbers use, and chill the lower metal section of the spark plug with either a chunk dry ice, or the drug store Wart removal spray chillers. Make metal temperature differences your assistant. Ding ding ding We (may) have a winna.
[Re: rscottick]
#2305480
05/16/17 01:54 PM
05/16/17 01:54 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
Way to much work.Saok it with a good penetrating oil. PB is like pea to me I used castle at work and now use the WD40 penetrant.Then work it back and forth easy.use a spark plug socket.at worki must have remover a few hundred that werefrozen.I used the ratchet to get them moving the used my 3/8 impact on real low to work them back and forth till they came out.Even with aluminum heads and had plugs that wer in for decades on some they came out and no damage.On my old ram charger snow plow truck the plugs were so bad that even a Snapon plug socket would not get them out.The crumbled.I finally got a metric socket on and worked them out.No damage.Rocky
Chrysler Firepower
[Re: 360view]
#2305787
05/16/17 11:36 PM
05/16/17 11:36 PM
Posts: 1,565 tennessee
pushbutton
tennessee
Never mind.
[Re: rscottick]
#2306550
05/18/17 08:31 AM
05/18/17 08:31 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Boy am I glad I moved away from the rust belt in 1985. If I had a car like that out here I'd call the scrapper because there is no way I'd even care to mess with it.
