successful first outing #2304536
05/14/17 10:00 PM
05/14/17 10:00 PM
Mt. Vernon, Ohio
dartman366 Offline OP
Mt. Vernon, Ohio
finally got decent weather to get the car out and do the maiden voyage on the new trick flow headed 512 and was very happy with the resuls, right out of the trailer it went 6.22@108.6 in the 1/8th mile, second pass was a little slower at 6.29@108.6 because of slippage on the line,(I failed to check the tire pressure and it was a little higher than it should of been by 2.5 pounds), so I footbraked both passes had 31* timing and shifted at 6200 to start out and the plugs are a little hotter than I usually run and the carb is a little fat so it's tunin' time. up
Re: successful first outing [Re: dartman366] #2304544
05/14/17 10:23 PM
05/14/17 10:23 PM
Good start thumbs
Now comes the fun part getting it maxed out wrench
Re: successful first outing [Re: Cab_Burge] #2304564
05/14/17 10:44 PM
05/14/17 10:44 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
yes, first thing is change oil and filter and put the colder plugs in, need to change the idle bleeds and clean up the idle a little then start working on the timing which should clean up the jetting a little before I put the AF sensor in and start charting that. wrench
Re: successful first outing [Re: dartman366] #2304570
05/14/17 10:47 PM
05/14/17 10:47 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Nice!
Re: successful first outing [Re: dartman366] #2304576
05/14/17 10:55 PM
05/14/17 10:55 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Nice!!
How does that compare to the old small block?
Re: successful first outing [Re: dartman366] #2304591
05/14/17 11:12 PM
05/14/17 11:12 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Good job.
[image][/image]
Re: successful first outing [Re: fast68plymouth] #2304603
05/14/17 11:29 PM
05/14/17 11:29 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
night and day difference, car pulled hard all the way thru but this is only 1/8 mile, next weekend at the Chrysler Power Classic at National Trails will be 1/4 mile so we will see, but I anticipate it to get better from here because I know there are a few things that I intentionally left conservative.
Re: successful first outing [Re: dartman366] #2304618
05/15/17 12:05 AM
05/15/17 12:05 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
If you bring the timing up a bit it may be happier and the afr's will change............I run an NGK 7 or 8 street/strip at 12.1.1 and VP-100 at the pump............. thumbs Good first outing and welcome to the BB zone............ beer
Re: successful first outing [Re: dartman366] #2304702
05/15/17 03:18 AM
05/15/17 03:18 AM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
First outings on rebuilt or new engines that go really well sure are satisfying, excellent to see it, bet you'll be really happy when you get it tuned
Re: successful first outing [Re: wyoming] #2304757
05/15/17 10:21 AM
05/15/17 10:21 AM
tboomer Online work
tboomer  Online Work
Nice job Bill! Your car is under 3000# if I remember?
Re: successful first outing [Re: dartman366] #2304766
05/15/17 10:43 AM
05/15/17 10:43 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
very nice. what was the compression and cam you put in it if ya don't mind me asking? just trying to figure what to expect with my 511 combo. thanks
Re: successful first outing [Re: dartman366] #2304838
05/15/17 01:18 PM
05/15/17 01:18 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Dam good for first time out - a little more timing and figure out your jetting - solid 9.60 car!
Re: successful first outing [Re: dartman366] #2304946
05/15/17 03:58 PM
05/15/17 03:58 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Sounds like a pretty good start to me. Keep chipping away at it and watch those numbers drop.
Re: successful first outing [Re: Al_Alguire] #2305042
05/15/17 06:42 PM
05/15/17 06:42 PM
an8sec70cuda Offline
iagree up
CHIP
'06 GMC 2500HD LBZ Duramax
Re: successful first outing [Re: an8sec70cuda] #2305051
05/15/17 06:58 PM
05/15/17 06:58 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Congratulations Bill. Now take that sucker out and quit babying it. Lol
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: successful first outing [Re: pittsburghracer] #2305205
05/15/17 10:45 PM
05/15/17 10:45 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
thanks guys,
Thumper, thats why I am going to pull the timing up a couple and then plug in the o2 sensor and start recording because I know that will change things.
Wyoming,it is a good feeling, even better when I h
changed the oil and filter and there was nothing in it in terms of debris.
Ted, I was at 2938# but probably a little havier than when the smallblock was in it.
Mopar Dave, compression is at 12.3 and cam is a bullit grind,,.690 lift both int@exh and I believe it's 272* duration but I would have to look at the card again.
DoubleD, I have wanted to do this for some time and now I wonder why I waited,,,,,oh now I know why,,MONEY!
Al, I was scared to death my first pass, by half track it went away.
Yes John, I will turn the wick up a little, hope I get to bring it to Keystone next month for the BGR race, I got vac time scheduled for it.
Re: successful first outing [Re: dartman366] #2305218
05/15/17 11:10 PM
05/15/17 11:10 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Traitor........ lol
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: successful first outing [Re: dartman366] #2305230
05/15/17 11:40 PM
05/15/17 11:40 PM
gregsdart Offline
gregsdart  Offline
Congrats on a great first outing!
Re: successful first outing [Re: dartman366] #2305280
05/16/17 01:01 AM
05/16/17 01:01 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
thanks dartman, your mill is more potent than mine as i have 11 to 1 comp and a 270* with .650". i figured mine would be done by 6500, according to yours it should be done by 6000. it will last a long time like that. good luck in your tuning, should be a fun mill for sure.
Re: successful first outing [Re: dartman366] #2305493
05/16/17 02:19 PM
05/16/17 02:19 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Trust me you will find more there. If you want to that is smile
