pilot bearing not fitting properly in crank
#2304351
05/14/17 03:20 PM
05/14/17 03:20 PM
Posts: 13 Raleigh, NC
NC-Challenger
Raleigh, NC
Hello All
I will be going with an A833 and I need some assistance for installing a pilot bearing in my 440 crank (FC66907.1). I went to install the pilot bearing and it inserted into the crank register by hand when it should install tighter with either a puller or tapped in with socket/hammer. Since the bearing is a bit loose (OD of bearing is 1.817", crank register is close to that), I'm wondering if my only option is to use a pilot bushing? The input shaft on my transmission measures 0.747" but the available pilot bushing (RAM BU286) looks to have a 0.754" OD, which may be too tight? If I use this bushing, does the ID need to be machined down? Any suggestions on how to proceed?
The crank pilot hole depth is 1.87" and the input shaft length from the trans housing face is about 8.38".Does shaft need to be shortened?
Thanks Chris
Re: pilot bearing not fitting properly in crank
[Re: NC-Challenger]
#2304402
05/14/17 04:41 PM
05/14/17 04:41 PM
Posts: 25,798 Rio Linda, CA
John_Kunkel
Rio Linda, CA
To use the original pilot bushing the crank bore must be .9375", most automatic cranks are only pilot bored to .915" and not reamed to final size. The original bushing is .940" OD but there are undersized bushings available for cranks that aren't finish reamed. http://www.ebay.com/itm/New-Undersize-Pi...0-/261638021109
[Re: John_Kunkel]
#2304406
05/14/17 04:50 PM
05/14/17 04:50 PM
NC-Challenger
Raleigh, NC
To use the original pilot bushing the crank bore must be .9375", most automatic cranks are only pilot bored to .915" and not reamed to final size. The original bushing is .940" OD but there are undersized bushings available for cranks that aren't finish reamed. http://www.ebay.com/itm/New-Undersize-Pi...0-/261638021109 Ok, thanks. I need to measure the pilot hole more accurately to see which bushing to go with.
[Re: NC-Challenger]
#2304413
05/14/17 04:54 PM
05/14/17 04:54 PM
John_Kunkel
Rio Linda, CA
Another alternative is to "tattoo" the FC bearing i.e. use a center punch and punch all around the periphery of the bearing to expand it; it should then fit tightly in the crank register.
[Re: John_Kunkel]
#2304488
05/14/17 08:14 PM
05/14/17 08:14 PM
NC-Challenger
Raleigh, NC
That's an interesting trick, I'll keep that in mind. Thanks.
[Re: NC-Challenger]
#2304554
05/14/17 10:32 PM
05/14/17 10:32 PM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
That's an interesting trick, I'll keep that in mind. Thanks. I have done the same thing in reverse, around the hole to shrink it, with aluminum frame windows when the screen clip holes have stripped....
