Re: CASCAR Hemi Intake by Arrow Racing on sale now
[Re: w2stroker]
#2313202
05/29/17 09:01 PM
05/29/17 09:01 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
I have a gen 3 at imm engines that Brian should have on the dyno soon. it has the tall ritter intake on it. we could get Brian to compare back to back with actual numbers That would be interesting. PM me, we can work out the details.
"Just a Bracket car dressed up like a streetcar"
[Re: hudsonhornet7x]
#2340731
07/21/17 12:39 AM
07/21/17 12:39 AM
Jamey
[Re: Jamey]
#2348841
08/05/17 09:06 AM
08/05/17 09:06 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
That's the EFI intake, not the carb one.
[Re: Supercuda]
#2349512
08/06/17 03:05 PM
08/06/17 03:05 PM
Jamey
That's the EFI intake, not the carb one. Yeah, I know it's for efi, but didn't think it'd cost any more than the carb version. They only ad 8 holes for the injectors. Plus the fuel rails and injectors aren't included. Not a big deal though, this hobby isn't cheap.
[Re: Jamey]
#2425923
12/30/17 04:57 PM
12/30/17 04:57 PM
Posts: 12,383 Taxes & Virus's R-US, NY
Dragula
That's the EFI intake, not the carb one. Yeah, I know it's for efi, but didn't think it'd cost any more than the carb version. They only ad 8 holes for the injectors. Plus the fuel rails and injectors aren't included. Not a big deal though, this hobby isn't cheap. What happened to the damn website?
Re: UPDATED WITH PICS ARROW SINGLE PLANE INTAKE
#2431747
01/09/18 07:05 PM
01/09/18 07:05 PM
Posts: 7,131 Amarillo, Texas
BBR
Amarillo, Texas
Carb intake is not listed. Just the EFI one. Boo.
Drag Week 2011 - 77th place - DD Drag Week 2012 - 2nd place SRBB N/A Drag Week 2014 - Kapooya RMRW 2018 RMRW 2020
#2444002
01/31/18 12:44 PM
01/31/18 12:44 PM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
Thank you Jordan,
Any plans on expanding the product list of G3 hemi parts?
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: ric3xrt]
#2444060
01/31/18 02:50 PM
01/31/18 02:50 PM
Posts: 3 MI
PREFIX
MI
Guys.
Here is and updated list of the parts we have and offer right now. We also have a few new things in our facility including two engine dynos, Spin tron and a chassis dyno.
Hemi Drag Pak Manifold (2015), tall plenum, 8.5" from head flange to TB flange. For 5.7L/6.1L/6.4L P50049330AC $1,250.00
Hemi Drag Pak Manifold adaptor for 4150 to 4500 throttle body, need to remove 38mm from manifold to use ARR-9330 $360.00
Hemi CASCAR Manifold, Mid-Rise, 5.9'' from head flange to TB flange. For 5.7L/6.1L/6.4L ARR-CAS-1010 $575.00
Hemi CASCAR Manifold, Mid-Rise, 5.9'' from head flange to TB flange. For 5.7L/6.1L/6.4L, EFI version ARR-7509-M $630.00
Hemi Gasket for Drag Pak and CASCAR intake manifolds ARR-1R1312060KF $14.00
Hemi Carb Stud Kit for CASCAR manifold (ARP) ARR-2403 $30.00 Hemi fuel rail kit for Drag Pak Manifold, black anodized with -8AN fittings ARR-3783 $270.00
Hemi CASCAR billet aluminum fuel rail brackets ARR-CRT-FUELBKT $25.00 EACH
Hemi CASCAR billet aluminum oil fill adaptor ARR-CRT-OILADPT $244.00
Cylinder Heads and ValveTrain Hemi 6.4L Apache CNC cylinder heads, mild port, with stock valves, no valvetrain ARR-6555HO/6556HO $3,836.60
Hemi Cast Aluminum Rocker Covers, black wrinkle finish, taller than stock, can use T&D rockers. For 5.7L/6.1L/6.4L ARR-2086 $840.00
Hemi Titanium Intake valve for ARR-6555HO/6556HO cylinder heads, 2.140" diameter ARR-CAS-1340 $149.00
Hemi Titanium Exhaust valve for ARR-6555HO/6556HO cylinder heads, 1.650" diameter TTE-1650-5090T $100.00
Hemi Locks (single groove) for Titanium valves ARR-CAS-1340 ARR-CAS-1330 $17.00
Hemi Ti Retainer for Stock 6.4L or PSI1500 series style springs ARR-CAS-1320 $31.00
Hemi Steel Reatiner for Stock 6.4L or PSI1500 series style springs ARR-761 $4.00
Hemi Steel spring seat for PSI 1500 series springs, fits 6.4L Apache cylinder heads ARR-1270 $5.00
Hemi PSI1511 springs (set), fit 6.4L Apache cylinder heads, max valve lift is 0.625" ARR-1511ML $280.00
Hemi Comp 7230 springs (set), fit 6.4L Apache cylinder heads, max valve lift is 0.675" ARR-7230-16 $290.00
Head Stud Kit Hemi Head Stud Kit (A1), will fit Aluminum Gen3 6.1L blocks ONLY P5155517 $249.00
Front Distributor Kit and Fuel Pump Hemi Front Distributor Kit, kits are for Gen3 6.1L blocks ONLY ARR-5929 $1,670.00
Hemi mechancial fuel pump (Holley B engine) for ARR-5929 Kit ARR-CAS-1230 $140.00
Hemi Distributor (Crane) ARR-1820-DIST $520.00
Hemi Distributor Plug Wires (Crane) ARR-1820-WIRES $86.00
Adjustable Camshaft Timing Gear Hemi Adjustable Camshaft Timing Gear with offest bushings (0,2,4,6,and 8 degree), will fit Gen3 6.1L blocks ONLY TBD $200.00
Hemi Adjustable Camshaft Timing Gear, offset bushings ONLY (0,2,4,6,and 8 degree bushings) ARR-61DB-0 thu 8 $25.00
Aluminum Engine Blocks Hemi Aluminum 6.1L engine block with billet main caps, unhoned at 4.114", up to 4.185", crank honed P5153898 $3,750.00
Hemi Aluminum 6.1L engine block with billet main caps, honed 4.125", up to 4.155", crank honed P5155507 $3,750.00
Hemi Crate Engines Hemi 392 Crate engine, EFI, with Holley HP control system, cast iron block, 540HP ARR-392CE $16,995.00
Hemi 426 Crate engine, EFI, with Holley HP control system, aluminum block, 620HP ARR-426CE $19,995.00
Hemi 426 Crate engine, with Carburetor/Distributor/Fuel pump, aluminum block, 620HP TBD
[Re: RylisPro]
#2514110
06/27/18 08:28 PM
06/27/18 08:28 PM
Posts: 20,159 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Looks like some very nice products are being produced.
