Re: Low deck 4500 intake manifold choices?
[Re: viperblue72]
#2303890
05/13/17 05:08 PM
05/13/17 05:08 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I didn't think the TG/4500 low deck had been available for quite a few years.
I'm sure if you hunt around some, you'll be able to find a M1 at some point.
If you have the clearance, I'm sure either the Victor or TF manifold with an adapter would make more power.
