Mini starter install wire routing problem #2303815
05/13/17 01:07 PM
05/13/17 01:07 PM
TC, Minnesota
Gabmando Offline OP
Gabmando  Offline OP
TC, Minnesota
Replacing starter of my 1973 Charger Rallye 340. The mini starter posts location is very different from the original starter. I can hook up the wires but there is interference with the steering column. I tried re-routing the wires but they either don't reach or interfere with something.
Do I need to extend the wires or do I need a different mini starter?
I don't recall having that problem with a 72 Charger 400CID I used to own years ago.
Re: Mini starter install wire routing problem [Re: Gabmando] #2303823
05/13/17 01:24 PM
05/13/17 01:24 PM
This is not the for sale forum!!! tsk
Re: Mini starter install wire routing problem [Re: RapidRobert] #2303894
05/13/17 05:20 PM
05/13/17 05:20 PM
TC, Minnesota
Gabmando Offline OP
Gabmando  Offline OP
TC, Minnesota
RapidRobert I have no idea if that's the ticket. Maybe a member here can let me know.
Re: Mini starter install wire routing problem [Re: Gabmando] #2303905
05/13/17 05:53 PM
05/13/17 05:53 PM
BDW Online content
BDW  Online Content
Looks like you're missing the standard extension that comes on the factory starter.
Don't think you need the special 1 mentioned above
Re: Mini starter install wire routing problem [Re: BDW] #2304529
05/14/17 09:44 PM
05/14/17 09:44 PM
this is it
Re: Mini starter install wire routing problem [Re: BDW] #2304734
05/15/17 08:58 AM
05/15/17 08:58 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
if that piece would fix it i have a couple laying around that you're welcome to. message me if so..
