Issues with Precision shifter rear pull bracket 47rh
#2303313
05/12/17 01:00 PM
05/12/17 01:00 PM
Posts: 468 Dirty Dena, Maryland
dodge turbo
Well we are using a 47rh in a diesel project and the bracket blocks the rear fluid port
We've called PPP several times with no solution. Seeing if any of you guys have had similar issues or solutions.
78 Adventurer 150small block turbo'd 360w/Borg S475....smoke'em
Re: Issues with Precision shifter rear pull bracket 47rh
[Re: dodge turbo]
#2303363
05/12/17 02:48 PM
05/12/17 02:48 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
How about plugging it off and drill and tap a hole from the top of that boss
JAKES AUTOMOTIVE
[Re: dodge turbo]
#2303390
05/12/17 03:37 PM
05/12/17 03:37 PM
Posts: 20,671 in a cattle trailer down by th...
Guitar Jones
Is that for the throttle pressure or the shifter? If it's for the shifter something isn't right, it doesn't even line up with the lever.
[Re: dodge turbo]
#2303394
05/12/17 03:44 PM
05/12/17 03:44 PM
Posts: 25,992 Rio Linda, CA
John_Kunkel
Rio Linda, CA
They should change their name to PPPP (P*ss Poor Prior Planning)
[Re: dodge turbo]
#2303411
05/12/17 04:12 PM
05/12/17 04:12 PM
Posts: 20,212 Park Forest, IL
slantzilla
Park Forest, IL
J-body had to fab his own bracket for a 727 too. There is a thread on here somewhere with pictures.
[Re: dodge turbo]
#2303413
05/12/17 04:17 PM
05/12/17 04:17 PM
Posts: 52,972 Romeo MI
MR_P_BODY
We've called PPP several times with no solution. Seeing if any of you guys have had similar issues or solutions. I run the 518 with the B&M shifter.. what is the distance from the trans ear to the bottom of that bracket hole.. looks like you can add a few washers to lower that bracket.. I had to add 2 or 3 washers to clear the lip of the pan.. as said already the shifter should be level so if its level you should have some distance to lower that bracket and you might need to trim the to of that bracket down so you just clear that trans ear
[Re: MR_P_BODY]
#2303429
05/12/17 05:11 PM
05/12/17 05:11 PM
dodge turbo
Its right against the hole for the fitting.
Im not plugging and tapping the case im not a hill billy
Just trying to see if anyone else is have this issue with the rear pull shifters
[Re: dodge turbo]
#2303474
05/12/17 06:43 PM
05/12/17 06:43 PM
JAKE68
Shelby mi.
HILL BILLY?????? Guess you don't know how to reengineer your way around. Or spell.
JAKES AUTOMOTIVE
[Re: JAKE68]
#2303484
05/12/17 06:57 PM
05/12/17 06:57 PM
MR_P_BODY
HILL BILLY?????? Guess you don't know how to reengineer your way around. I agree with Jake... the easiest way to get around this issue is to drill and tap the top of the boss and plug the current hole... that way your cable would line up ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: JAKE68]
#2303576
05/12/17 10:05 PM
05/12/17 10:05 PM
dodge turbo
Im very well educated for one so dont get butt hurt that i dont want to be a hack.. And two im not re-engineering a transmission port, thats plain dumb when i can just build another bracket.
I made a post to see if this is a common theme with the precision shifters or not.
[Re: dodge turbo]
#2303598
05/12/17 10:53 PM
05/12/17 10:53 PM
JAKE68
Shelby mi.
Sounds like it's more dumb to have to-reengineer a hole bracket and make everything line up when doing the hole could have been done in a short time. I was only trying to make your life easier But since you have all the brains then why did you have to even put up this post. Seams like you try and help someone and they blast you and call you dumb. I'm out of here........
JAKES AUTOMOTIVE
[Re: dodge turbo]
#2303696
05/13/17 02:38 AM
05/13/17 02:38 AM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
[Re: dodge turbo]
#2303721
05/13/17 07:31 AM
05/13/17 07:31 AM
Guitar Jones
On top of that the 47 uses a half inch cooler line instead of the 727s five sixteenths. I would make another bracket and possibly use some steel braided hose with a 45 degree fitting or something like that.
Good luck with your truck, what valve body are using?
