Why do 6" wheels require 11" or disc brakes #2302440
05/10/17 03:39 PM
05/10/17 03:39 PM
MA
ragtop Offline OP
ragtop  Offline OP
MA
In the 1971 Dodge service manual. It says that 6" wide wheels require either 11" drum brakes or disc brakes. Anyone know why?
Thanks.
Re: Why do 6" wheels require 11" or disc brakes [Re: ragtop] #2302477
05/10/17 04:55 PM
05/10/17 04:55 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
can you post a picture of the actual page/comment?
I believe it is the other way around .....
the B & E body cars with 11" brakes STANDARD had 14x6.0" wheels STANDARD
ordering F70-14 tires on a /6 or 318 car required "rallye suspension" which also would get you the 14x6.0" wheels
disc brakes also may have required the 14x6.0" wheels
work but all of the above could've been ordered with "Rallye" or "Road" wheels which were 14x5.5"
Re: Why do 6" wheels require 11" or disc brakes [Re: ragtop] #2302509
05/10/17 05:57 PM
05/10/17 05:57 PM
MA
ragtop Offline OP
ragtop  Offline OP
MA
This is how it appears in the manual...
"** 6JJ & 7JJ rims require 11" drum or disc brakes"
What you say, makes sense, I wonder if the factory worded it wrong
Re: Why do 6" wheels require 11" or disc brakes [Re: ragtop] #2302512
05/10/17 06:00 PM
05/10/17 06:00 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
What they are saying is if you want to have 6" or 7" wheels then you need to buy better brakes or we won't sell those big wheels to you. Bigger wheels and tires haul more weight and they want the brakes upgraded.
Re: Why do 6" wheels require 11" or disc brakes [Re: ragtop] #2302523
05/10/17 06:14 PM
05/10/17 06:14 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Not required any more than 3.54 gears require drum brakes, or 4.10 gears require disc brakes.
They're saying they delivered them that way.
Not that nothing else will ever work.
Re: Why do 6" wheels require 11" or disc brakes [Re: NANKET] #2302527
05/10/17 06:18 PM
05/10/17 06:18 PM
MA
ragtop Offline OP
ragtop  Offline OP
MA
What you say also makes sense, but how would you go about ordering the 6" wheel? Also if you ordered any of the four following 1971
B - body tires (G78 x 14, H78 x 14, F70 x 14, or G70 x 14) which comes with 6" rims, it does not tell you anywhere that I could find, that you are required to purchase H.D. brakes (aka 11"), or disc brakes.
Re: Why do 6" wheels require 11" or disc brakes [Re: ragtop] #2302537
05/10/17 06:29 PM
05/10/17 06:29 PM
Chicago
PurpleBeeper Offline
Chicago
What if it's the other way around? If you want the good brakes, you must buy these wheels & they're not available without the brakes? There might be some brake clearance issues with smaller wheels.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Why do 6" wheels require 11" or disc brakes [Re: ragtop] #2302539
05/10/17 06:33 PM
05/10/17 06:33 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
what body & model are "WE" talking about?
you couldn't specifically "order" 6" wheels - the only wheel OPTIONS were the "Rallye" & "Road" wheels
when larger tires were ordered, they included the wheels that Chrysler spec'd for that size tire
when significantly larger than stock tires were ordered, the guides specified larger brakes and/or suspension were required
Re: Why do 6" wheels require 11" or disc brakes [Re: ragtop] #2302574
05/10/17 08:54 PM
05/10/17 08:54 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
You don't order a car from the service manual. If a certain wheel tire, or brake combo was wanted then when the dealer would speck it out that way. But , I guess if you had such car, and wanted to install something different, the service manual was telling what was required.
Re: Why do 6" wheels require 11" or disc brakes [Re: 71birdJ68] #2302653
05/11/17 12:08 AM
05/11/17 12:08 AM
MA
ragtop Offline OP
ragtop  Offline OP
MA
I think 6bblgt is correct in stating that on B and E body's with either H.D. sups., HD brakes, or disc brakes got the 6" steel wheels unless you ordered the Rallye or Road wheels. I was incorrect in stating that there were four different 1971 B - body tires that got the 6" rim as std. I think that only the G70 x 14 got the 6" rim as std., but I found a side note stating that G70 x 14 tires required HD susp. So now I think that accounts for all 6" rims end up getting HD brakes or disc.
