Re: Mopar P5155469 magnum RT heads
[Re: mgoblue9798]
#2302519
05/10/17 06:10 PM
05/10/17 06:10 PM
Posts: 17,876 S.E. Michigan
ZIPPY
S.E. Michigan
The original magnum r/t heads p5007140 and 71, etc, were proprietary MP parts.
The P515-series are called "magnum r/t" in the marketing materials, however they are 100% an enginequest head which Chrysler has not done anything to at all. I don't even think the packaging is different. Note, my information is from 2013.
I didn't agree with that decision but that was two jobs ago, and at the time the powers that be weren't having it any other way.
Rich H.
Esse Quam Videri
[Re: mgoblue9798]
#2302561
05/10/17 07:48 PM
05/10/17 07:48 PM
RapidRobert
Now I just need to find who sells the bare EQ heads cheap. You might locate/call an Eric Haugland of Las Vegas an importer of them. He gave me a good deal on a pair & I bought mine bare. I don't have his # offhand. EDIT circle burners are kicking a$$ & taking names with those heads, Mopar & chebby, many good reports on em.
[Re: mgoblue9798]
#2302797
05/11/17 11:49 AM
05/11/17 11:49 AM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
The EQ heads flow better out of the box than the RT's, no cracking issues like the other Magnums and less expensive.
Carl Kessel
[Re: CKessel]
#2302833
05/11/17 01:27 PM
05/11/17 01:27 PM
dogdays
EngineQuest (EQ) is the engine parts division of A&A Midwest. www.aamidwest.com Ebay ad: http://www.ebay.com/itm/CHRYSLER-318-360-CYLINDER-HEAD-MAGNUM-ENGINEQUEST-BARE-/142072747238?hash=item21143214e6:g:w8QAAOSwQJhUj2QX&vxp=mtr Here's where you have to be careful. There are at least three replacement cast iron heads for Mag engines. The good ones are poured and machined in New Zealand. Check Alibaba.com to see the other manufacturers. So when you purchase the heads online it is imperative especially as there is little difference externally. The MSRP for a bare EQ head is $349.99 each, shipped. If they are built for Mag engines they will probably use valves with 8mm stems. I don't think you are going to get a new set for less than $1200. That's pretty close to aluminum. R.
[Re: mgoblue9798]
#2302873
05/11/17 03:05 PM
05/11/17 03:05 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
It is easy to pick out a real EQ they are flat on the end instead of a bunch of bossess sticking out. Also if you have them in your hand the casting texture is way nicer on the EQ than the chinese crap and the ports are much bigger and smoother, the chinese ones have very rough ports that are noticably smaller than a stock one.
[Re: HotRodDave]
#2303525
05/12/17 08:26 PM
05/12/17 08:26 PM
Posts: 1,822 Colorado
denfireguy
Colorado
This guy is local to me. I bought a replacement from him a couple of years ago. Good service and good quality part. Mine are 2.02 intake valves.I am sure he would well them any way you want them.
Craig
http://www.ebay.com/itm/MOPAR-EQ-CH318A-5-9-MAGNUM-NEW-BARE-HEAD-5-2-DODGE-318-360-340-X-OVER-UPGRADE-/380629437262?hash=item589f484b4e:g:Ph8AAMXQWzNSn3M1&vxp=mtr
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: denfireguy]
#2305020
05/15/17 06:12 PM
05/15/17 06:12 PM
dogdays
