Holley tuning problems #2302421
05/10/17 03:02 PM
05/10/17 03:02 PM
libby mt
montanamopar92 Offline OP
libby mt
K truck is a 81 d150 354 gears, headers com cam, Eddy 4brl intake, nothing to extreme. Carn is a Holley 600. Problem is if u stab the gas at a stop it pops an dies or if I let off as soon as it pops it's fine. I swapped the 65 Jets out an swapped to 61s as that's what I was told to do. I'm still running the #31 squirter an am thinking of swapping to a #28.. truck fire up an idles great! I have been told the 31 is just a bit much..timing is dead on so only thing it could be is carb related. Any help would be much appreciated
Re: Holley tuning problems [Re: montanamopar92] #2302463
05/10/17 04:35 PM
05/10/17 04:35 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I had the same problem with my Dart. 50cc accel. pump was the cure.
Re: Holley tuning problems [Re: Dave Hall] #2302495
05/10/17 05:33 PM
05/10/17 05:33 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
since leaner jets didn't help, go up to 70 jets, readjust idle mix after it warms up, then see how it drives.
Re: Holley tuning problems [Re: montanamopar92] #2302540
05/10/17 06:33 PM
05/10/17 06:33 PM
Chicago
PurpleBeeper Offline
Chicago
Is this a new problem or has the motor always done this? Did it ever "work fine" before?
You might want to take a look down the throat of the carb and see if your squirter is working. Maybe wire shut the secondaries with a bread tie and see if the "pop" goes away?
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Holley tuning problems [Re: montanamopar92] #2302570
05/10/17 08:30 PM
05/10/17 08:30 PM
CA
crackedback Offline
crackedback  Offline
CA
Timing is "dead on"...
So what is the timing profile, initial, total and all in point?
Seen this too many times and it's not what most people think is the issue.
Re: Holley tuning problems [Re: Dave Hall] #2302712
05/11/17 02:46 AM
05/11/17 02:46 AM
libby mt
libby mt
Sprayer works great. I was deff running rich as the carb was black an an plugs were black an smelled like fuel real bad. Old timer told me to swap to 61s an bump the squirter size down to a 28. Motor is a 318, headers, comp cam, flat tops nothing super aggressive
