Re: 440 oil pan gasket question...
[Re: moparrush]
#230237
02/20/09 01:28 PM
02/20/09 01:28 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Moparrush...........You will need 2 pan gaskets for use with a windage tray. It is also a good idea to attach the gaskets to the windage tray only and I would use the good 'ol brown gasket gasket shellac (sparingly) from Permatex no other sealers are required. I agree with Moparlifer with the Superformance Products #2585 pan gasket. It's stick resistant coated and can be reused, packaged flat so it won't take a week or so to get the kinks out of the Fel-Pro and simply it's a better material. I'd give Superformance a call 1-866-925-7855 http://www.superformanceproducts.com or they are available from Chenoweth Speed & Machine 309-266-8084. Priced rite and good stuff!!!
