904 trans case issue #2301987
05/09/17 09:23 PM
05/09/17 09:23 PM
MD
RTSE4ME Offline OP
RTSE4ME  Offline OP
MD
Putting together a 904 and noticed this crack on the inside. You can feel the a bump where the crack is. The outside of the case doesn't have any marks but you can feel a low spot.
Is the case junk?
Re: 904 trans case issue [Re: RTSE4ME] #2302039
05/09/17 10:29 PM
05/09/17 10:29 PM
if this is on the outside of the bellface where it took a hit I would be inclined to say you're good.
Re: 904 trans case issue [Re: RTSE4ME] #2302050
05/09/17 10:45 PM
05/09/17 10:45 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
I would at least drill a small hole at the end of each crack to prevent it from cracking further. Probably would not cost much to have those welded just for peace of mind.
Re: 904 trans case issue [Re: mgoblue9798] #2302080
05/09/17 11:11 PM
05/09/17 11:11 PM
MD
RTSE4ME Offline OP
RTSE4ME  Offline OP
MD
What concerns me is the bump where the crack is. It seems like someone dented the outside of the case. It is hard to tell in the picture. I have a spare 904 and I will use that case.
Just odd there are no marks on the outside of the case.
Re: 904 trans case issue [Re: RTSE4ME] #2302099
05/09/17 11:38 PM
05/09/17 11:38 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
Based on your description and the fact that it is in a high stress area IE: O/R clutch, I'd use the other case.
Why worry about it later ?? twocents shruggy popcorn
Re: 904 trans case issue [Re: RTSE4ME] #2302186
05/10/17 03:19 AM
05/10/17 03:19 AM
BDW Offline
BDW  Offline
How about a pic of the other side
Re: 904 trans case issue [Re: RTSE4ME] #2302216
05/10/17 06:45 AM
05/10/17 06:45 AM
Guitar Jones Offline
I wouldn't use it.
Re: 904 trans case issue [Re: RTSE4ME] #2302253
05/10/17 09:39 AM
05/10/17 09:39 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Weld it up and keep for a spare. Whole lot of top fuel blocks are welded. I think they see more stress than that case.
Re: 904 trans case issue [Re: cudaman1969] #2302290
05/10/17 11:23 AM
05/10/17 11:23 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Pretty sure the top fuel guys don't just cross their fingers and hope the weld is good. Bet they NDT it.
Don't be the exception.
Re: 904 trans case issue [Re: BDW] #2302296
05/10/17 11:26 AM
05/10/17 11:26 AM
MD
RTSE4ME Offline OP
RTSE4ME  Offline OP
MD
Looks like something hit on the parting line. My eyes are getting old so I didn't see it without the camera ...need glasses. The trans is going in a 2200lb drag car.
Re: 904 trans case issue [Re: Supercuda] #2302453
05/10/17 04:07 PM
05/10/17 04:07 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
If, the welder is good the welded piece is stronger. Just because somethings broke don't mean it's throw away.
