NSS racers,,,carb / intake questions #2300938
05/07/17 11:44 PM
05/07/17 11:44 PM
KENTUCKY
69CHARGERMD Offline OP
KENTUCKY
I might try and make it to Bowling Green for the Doug Duell race May 18-21
I have a 65 Belvedere that I will need to make a few changes to fit the rules,,mostly carb/intake issues.
Currently have a Victor intake and 1050 Dominator.
( i read the rules so i realize i need either a carter, AFB, edelbrock )2x4 or 1x4 set up.
I have TWO carter 750 carbs at home ( came of a previous NSS race car,,,but never ran them on mine ),,,so i will have a "friend" go thru them with me,,,
I can either run a adaptor for my victor intake and bolt on one of the 750s ???
Does the INDY 2x4 intake bolt or work with Edelbrock RPM heads ?? Will this only work if the heads are max wedge port(ed)?
Car runs 10 teens usually as it sits with the dominator ( best was a 10.04 ),,,
I am thinking I could run the 10.50 index ? with one carb and the adaptor ?
I don't know what it would do with the 2x4 set up ?
This is all NEW to me,,,so i am trying to find my way with the setup,,,,
really don't want to mess with how the car is currently set up,,,but would like to try some NSS stuff
any help appreciated
Doug
Re: NSS racers,,,carb / intake questions [Re: 69CHARGERMD] #2300956
05/08/17 12:16 AM
05/08/17 12:16 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Nss is poular and a great class.Tight racing with those guys.You need to install thw duwl 4's and make some test hits to se were you land.Then tune for where you want to be. GIVE EM hell!!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: NSS racers,,,carb / intake questions [Re: 69CHARGERMD] #2301026
05/08/17 07:23 AM
05/08/17 07:23 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Brett Wheeler is running the Indy Mod Man with two Eddys. His car runs B index, 10.50. I thinks its even run A 10.0 at times.
Doug
Re: NSS racers,,,carb / intake questions [Re: 69CHARGERMD] #2301114
05/08/17 12:41 PM
05/08/17 12:41 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
If you want to run NSS and have stock intake ports, the Indy modman, edelbrock 2x4 are the cheapest bolt on manifolds. I ran a 64 crossram with at first with 906 heads ported close to maxwedge, you can't get them all the way, and then the crossram with victor Jr. heads with max wedge ports. I now run a victor intake with a fabricated 2x4 top. I run 750 AFB carbs on all those combinations. Their is a little difference in NSS rules with different groups, for example no single four combos are allowed with the Victory series NSS. So check with the group you want to run with. I would probably choose the modman intake with your combination. Some say a divider installed in the plenum picks this manifold up a little. I started on the 11.00 index now run 9.75 Lot of guys worry about getting the AFB's to run, but with a few minor modifications they run very well. I know several NSS cars in the 8's with a pair of AFB's.
Re: NSS racers,,,carb / intake questions [Re: 69CHARGERMD] #2301173
05/08/17 02:27 PM
05/08/17 02:27 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
That race is NMCA rules -
•Chrysler Wedge;Inline or cross-ram 2x4 or single 4bbl intake with Carters, AFBs, or Edelbrocks
The other issue is hood scoop
HOOD/SCOOP (NSS Classes): Hood scoops limited to OEM equipment or period style. Hood/scoop may be no higher than 5 inches. Pro stock-style scoops prohibited. The entire induction system must be completely covered by hood or scoop, which must be part of the vehicle hood. (FX Classes): Not required
Re: NSS racers,,,carb / intake questions [Re: 69CHARGERMD] #2301228
05/08/17 04:19 PM
05/08/17 04:19 PM
Georgia
66coronet Offline
66coronet  Offline
Georgia
Doug is correct. I run the modman and run mostly B. I run A when it just doesn't make sense to slow the car down .60. Meaning if i look at the weather and can go 9.85-9.90, I move the car to A. Otherwise I just back it up to run B.
The modman will bolt up to your heads and work just fine. I have mine opened up to Max Wedge ports to match my SR ports.
My tests were not true back to back tests. I had a fuel delivery issue on my last pass with a single plane and single holley. I do not think there is any more than 5 hundredths between the intakes on my car.
It should serve you well. If you are in Kentucky, you have a ton of opportunities for NSS races with relatively short tows.
Re: NSS racers,,,carb / intake questions [Re: 69CHARGERMD] #2301324
05/08/17 07:59 PM
05/08/17 07:59 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
I think the modman would be your best bet, seen several cars with them and everyone was happy with them.
As for the carbs, put the 2 750's on, start with stock jetting and metering rods. Put the pump rod in the top hole (biggest pump shot) and check linkage for wot. You should be close enough to have a fun weekend.
Re: NSS racers,,,carb / intake questions [Re: 69CHARGERMD] #2301667
05/09/17 12:09 PM
05/09/17 12:09 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
Hey Doug how you been? The 440 in the 65 when you bought it from me , would run 10.50 in the 1/4 with 2 Edelbrock 750. But that was with a mopar M1 Tunnel Ram. So with your new engine you shouldn't have a problem hitting your ET goal
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: NSS racers,,,carb / intake questions [Re: 69CHARGERMD] #2301690
05/09/17 12:34 PM
05/09/17 12:34 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
My brother ran the Modman intake and two Eddy (Carter) carbs on his 64 and it dipped into the 10.0's. The club he runs with the 422 club changed their rules and he can now run any single carb and intake. So he switched to the Indy single plane and a Dominator and has run only about a tenth faster as his best now is 9.94. Ron
Re: NSS racers,,,carb / intake questions [Re: 69CHARGERMD] #2302097
05/09/17 11:37 PM
05/09/17 11:37 PM
KENTUCKY
KENTUCKY
Thanks everyone for the help!! I have 2 750 carbs ready to go. I will look into the Indy Modman and do some research. Doubt I will be ready for Bowling Green so might end up spectating. Thanks again for the help. Doug
Re: NSS racers,,,carb / intake questions [Re: 69CHARGERMD] #2302248
05/10/17 09:31 AM
05/10/17 09:31 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Doug, the mod man will work but I think the indy cross ram that most of the nss racers use make way more power. Jake
JAKES AUTOMOTIVE
Re: NSS racers,,,carb / intake questions [Re: 69CHARGERMD] #2302281
05/10/17 11:05 AM
05/10/17 11:05 AM
KENTUCKY
KENTUCKY
Jake. Will that work with E heads ?
Re: NSS racers,,,carb / intake questions [Re: 69CHARGERMD] #2302284
05/10/17 11:14 AM
05/10/17 11:14 AM
Georgia
66coronet Offline
66coronet  Offline
Georgia
I believe he is limited by port size.
You can always give it a shot with a single carb for the Dave Duell classic. Some folks have no issues with single edelbrock carbs, some fight a bog. It would get you to the race.
Re: NSS racers,,,carb / intake questions [Re: 69CHARGERMD] #2302414
05/10/17 02:54 PM
05/10/17 02:54 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
yes it will you may have to use one of those 2 piece valley covers.
JAKES AUTOMOTIVE
Re: NSS racers,,,carb / intake questions [Re: 69CHARGERMD] #2302423
05/10/17 03:06 PM
05/10/17 03:06 PM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
Don't think the port dimensions are going to work on this one (unless you plan on changing heads too?).
But, I am not a NSS racer so I will go back under my rock now.
Rich H.
Esse Quam Videri
Re: NSS racers,,,carb / intake questions [Re: JAKE68] #2302434
05/10/17 03:25 PM
05/10/17 03:25 PM
Georgia
66coronet Offline
66coronet  Offline
Georgia
I am sure the -25 intake makes more power, but I would like to see them back to back with the same carbs just to see the difference.
Mine was an existing car that I converted the induction on to become NSS legal. The modman and spacers for restrictor plates fit under my hood scoop without modification. The -25 and spacers would not. So I went the modman route.
Re: NSS racers,,,carb / intake questions [Re: 69CHARGERMD] #2302592
05/10/17 10:09 PM
05/10/17 10:09 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
I cant add any real info on the best intake to run, since all I've run in the class is either the stock crossram and the Indy one, but I will strongly recommend the DD Classic, its a great race to attend. Lots of really good cars to race, at a great old track. My advice, figure out something and drive on down.
Re: NSS racers,,,carb / intake questions [Re: wyoming] #2302631
05/10/17 11:38 PM
05/10/17 11:38 PM
Ohio
racerAL Offline
racerAL  Offline
Ohio
I've ran one NMCA NSS event and I chose to use a single Eddy 850cfm carb(on e85). The dual 4 set up just wasnt something I was interested in investing in for only a handful of races at most. It was my first try at a NSS event and I was a .10 off my index and had no idea how to go about slowing it down .50 to be able to go up an (nss/d 11.50) index with only two time runs. I wasnt prepared for the race and I took it all in as experience. I'll be more ready for the next time I run a NSS event. I had no issue with a bog footbraking my car with the single 4 carb. I just wasnt very good at it since I had never footbraked my car before..like I said I wasnt prepared..lol. I suggest doing whatever you decide very quickly and get some laps in with whichever combo you decide to use. I was a sitting duck when eliminations came around and I knew it..but all in all I had a blast racing with the group and will definitely do it again.
-1967 Plymouth Satellite #3555
446 cid on E-85
best 1/4 et 10.577 @ 127.58
best 1/8 et 6.722 @ 100.68
best 60ft. 1.419
Re: NSS racers,,,carb / intake questions [Re: 69CHARGERMD] #2302674
05/11/17 12:27 AM
05/11/17 12:27 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Doug I forgot to mention the Indy requires a maxwedge port.
JAKES AUTOMOTIVE
Re: NSS racers,,,carb / intake questions [Re: 69CHARGERMD] #2302813
05/11/17 12:27 PM
05/11/17 12:27 PM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
No chance of a single holley in the NSS classes?
Ohio about as close as the races come to NY state ?
