4 Link Help #230215
02/20/09 03:31 AM
02/20/09 03:31 AM
Riverside, California
Lil Demon Offline OP
I need some quick help as I have completely redone my 4 link settings. The bottom diagnal bar are the brackets where the heims go in supposed to be able to rotate or are they supposed to be completely tight?
Re: 4 Link Help [Re: Lil Demon] #230216
02/20/09 06:59 AM
02/20/09 06:59 AM
Q
Quicktree Offline
Quicktree  Offline
Q
I tighten mine
Re: 4 Link Help [Re: Quicktree] #230217
02/20/09 08:35 AM
02/20/09 08:35 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
ive got mine where they do rotate but you have to use a fair amount of force by hand.
Re: 4 Link Help [Re: bonefish] #230218
02/20/09 08:46 AM
02/20/09 08:46 AM
Lebanon,IN
mr2performance Offline
Lebanon,IN
tighten em, sometimes they will rotate on their own however Mike
MR2PERFORMANCE RACE CARS 765 483 9371
Re: 4 Link Help [Re: mr2performance] #230219
02/20/09 09:35 AM
02/20/09 09:35 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Mine are tight
Re: 4 Link Help [Re: Lil Demon] #230220
02/20/09 06:00 PM
02/20/09 06:00 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
.......tight...but they will rotate....on some customers cars whom that bugged them I actually drilled and tapped the hole for a 1/4" bolt....it's one of those whatever floats your boat things.
Re: 4 Link Help [Re: Chassisman] #230221
02/20/09 08:36 PM
02/20/09 08:36 PM
It's on the ground. Shocks at 4/4, IC 43 out 6 up. Rearend is up 1.5" from before, nose is down 1/22" from before - now sits with a 1" rake. I like it.
Engine, with proper timing now, sounds very crisp. No leaks and plenty of oil pressure.
Ready to go for tomorrow.
Re: 4 Link Help [Re: Lil Demon] #230222
02/20/09 09:29 PM
02/20/09 09:29 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
...like I said sounds like a good baseline to start at...of course you'll need about 15-20 passes to dial it in from there....but wait...you only got what "maybe" 6-10 before the March Meet?...LOL....BTW...guess what Im gonna run out of the box?....maybe 10.77?
Re: 4 Link Help [Re: Chassisman] #230223
02/20/09 11:36 PM
02/20/09 11:36 PM
6-10 - I doubt it - probably closer to 3-4, we'll see what happens tomorrow. But, it is supposed to start raining Sunday and not stop until after next weekend which means this is my only shot. Launch, all out, run the number in that order. I get 2 qualifying shots in Bakersfield and I'm probably going to need them, whereas last year I nailed it on the first one and was able to experiment on the second run.
If I see 10.77 on your window again, I swear I'm gonna run up just before the burnout and change it with my shoe polish. That's just not right only running a car once a year and it repeats the number. Sheesh.
