10" Drum Brake Identification #2301154
05/08/17 01:58 PM
05/08/17 01:58 PM
Southern Maryland
preddy Offline OP
preddy  Offline OP
Southern Maryland
I have a 1968 Barracuda and the previous owned put a shortened Dana 60 with Mosher axles in it. It has 10" drum brakes of an unknown origin. I asked the previous owner if he knew where they came from and he does not know. They brakes are also missing the emergency brake pieces. :\
Is there a way to tell what year they are and where they came from? For example, if I knew they were from a 73 A body, it would make tracking down parts a lot easier. I read that 68 10" drums are hard to find parts for. Thanks.
Re: 10" Drum Brake Identification [Re: preddy] #2301165
05/08/17 02:10 PM
05/08/17 02:10 PM
the shoe width might likely help pin it down (year/model) & I would measure across the horizontle e brake lever distance & have that dimention in hand so if someone has some pieces in hand but likely someone will pin this down to a group of years/models.
Re: 10" Drum Brake Identification [Re: RapidRobert] #2301179
05/08/17 02:34 PM
05/08/17 02:34 PM
Southern Maryland
preddy Offline OP
preddy  Offline OP
Southern Maryland
The shoe width is 2.5". There is no e-brake lever or any pieces related to the ebrake which is my next challenge once I figure where these brakes came from. I see no part numbers or anything I can lookup.
Re: 10" Drum Brake Identification [Re: preddy] #2301180
05/08/17 02:36 PM
05/08/17 02:36 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Depends, basically there are two 10" drum setups. The early A body that had the 4" bolt pattern and then everything else. I believe the early A body shoes are less than 2" wide, so if you have those you are dealing with the harder to find setup.
Assuming the PO didn't reuse the 68 A body backing plate and redrilled the drums you should be able to use the everything else 10" drum setup.
Don't be the exception.
Re: 10" Drum Brake Identification [Re: preddy] #2301186
05/08/17 02:42 PM
05/08/17 02:42 PM
I'm thinking it is the common any year BBP 10" drum assy.
Re: 10" Drum Brake Identification [Re: preddy] #2301230
05/08/17 04:23 PM
05/08/17 04:23 PM
Southern Maryland
preddy Offline OP
preddy  Offline OP
Southern Maryland
Supercuda/RapidRobert thanks for the quick response. It sounds like I'm dealing with a standard, 10" drum and parts should be relatively easy to find. He did not re-drill the drums. They look untouched. Thanks!
Re: 10" Drum Brake Identification [Re: preddy] #2301635
05/09/17 11:02 AM
05/09/17 11:02 AM
moparx Offline
moparx  Offline
i believe megaparts carry all the missing e-brake parts, and although i have never dealt with them, their reviews i have seen and heard about are all positive.
beer
Re: 10" Drum Brake Identification [Re: preddy] #2301796
05/09/17 03:38 PM
05/09/17 03:38 PM
BDW Online content
BDW  Online Content
This should help
Re: 10" Drum Brake Identification [Re: preddy] #2301837
05/09/17 04:54 PM
05/09/17 04:54 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The shoes in the pic show a round hole where the parking brake lever attaches, later shoes have a rectangular hole. These are the parts you need:
http://www.partsmix.com/products/mopar-1962-75-parking-brake-levers-for-10-rear-drum-brakes.html
http://www.partsmix.com/products/mopar-6...-10-brakes.html
Re: 10" Drum Brake Identification [Re: John_Kunkel] #2301973
05/09/17 08:43 PM
05/09/17 08:43 PM
Southern Maryland
preddy Offline OP
preddy  Offline OP
Southern Maryland
Thanks to everyone for responding. This is a really big help.
Re: 10" Drum Brake Identification [Re: preddy] #2302022
05/09/17 10:18 PM
05/09/17 10:18 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
That's a nasty road runner by the way.....
Re: 10" Drum Brake Identification [Re: buildanother] #2302024
05/09/17 10:20 PM
05/09/17 10:20 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
? RR?
Re: 10" Drum Brake Identification [Re: buildanother] #2302164
05/10/17 01:51 AM
05/10/17 01:51 AM
Southern Maryland
preddy Offline OP
preddy  Offline OP
Southern Maryland
Thank you. I'm trying to build a nastier cuda smile Same engine and about 600 lbs lighter.
Re: 10" Drum Brake Identification [Re: preddy] #2302318
05/10/17 11:58 AM
05/10/17 11:58 AM
Michigan Detroit area
Doc Schwarz Offline
Doc Schwarz  Offline
Remember there called parking brake parts, not emergency.
Learned that from lawyers.
Re: 10" Drum Brake Identification [Re: Doc Schwarz] #2302344
05/10/17 01:00 PM
05/10/17 01:00 PM
Southern Maryland
preddy Offline OP
preddy  Offline OP
Southern Maryland
Noted. Good point. wink
