Do U use Driven Hot Rod oil or Amsoil Z Rod? #2300878
05/07/17 10:12 PM
05/07/17 10:12 PM
long time lurker, short time p...
P
PorkyPig Offline OP
PorkyPig  Offline OP
P
Does anyone have experience with either the Driven Hot Rod or Amsoil Z Rod oils? If so, what viscosity are you using and in what engine and power range? I know both brands make some race only oils, but don't think that's what I'm looking for with a street strip 440.
Re: Do U use Driven Hot Rod oil or Amsoil Z Rod? [Re: PorkyPig] #2300888
05/07/17 10:31 PM
05/07/17 10:31 PM
California
mickm Offline
mickm  Offline
California
I just started using Z Rod. I'm using 20-50 in a 540 hemi that I take to about 6k. I just made the switch, and can't say I've noticed anything one way or the other. I put my engine together from parts from Tim Banning at FHO, and this is what he recommends, so why not?
Re: Do U use Driven Hot Rod oil or Amsoil Z Rod? [Re: PorkyPig] #2301029
05/08/17 07:52 AM
05/08/17 07:52 AM
Canada north shore lake Ontari...
ross Offline
ross  Offline
I have being using Amsoil 20-50 zrod for years in my solid lifter 451.Roughly 550hp.
Re: Do U use Driven Hot Rod oil or Amsoil Z Rod? [Re: ross] #2301943
05/09/17 07:44 PM
05/09/17 07:44 PM
P
PorkyPig Offline OP
PorkyPig  Offline OP
P
Thanks. I don't want to run 20w50, but will check out the lighter weight oils.
