NSS racers,,,carb / intake questions
#2300938
05/07/17 11:44 PM
05/07/17 11:44 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
I might try and make it to Bowling Green for the Doug Duell race May 18-21 I have a 65 Belvedere that I will need to make a few changes to fit the rules,,mostly carb/intake issues. Currently have a Victor intake and 1050 Dominator. ( i read the rules so i realize i need either a carter, AFB, edelbrock )2x4 or 1x4 set up.
I have TWO carter 750 carbs at home ( came of a previous NSS race car,,,but never ran them on mine ),,,so i will have a "friend" go thru them with me,,,
I can either run a adaptor for my victor intake and bolt on one of the 750s ???
Does the INDY 2x4 intake bolt or work with Edelbrock RPM heads ?? Will this only work if the heads are max wedge port(ed)?
Car runs 10 teens usually as it sits with the dominator ( best was a 10.04 ),,,
I am thinking I could run the 10.50 index ? with one carb and the adaptor ? I don't know what it would do with the 2x4 set up ?
This is all NEW to me,,,so i am trying to find my way with the setup,,,, really don't want to mess with how the car is currently set up,,,but would like to try some NSS stuff
any help appreciated Doug
Re: NSS racers,,,carb / intake questions
[Re: 69CHARGERMD]
#2300956
05/08/17 12:16 AM
05/08/17 12:16 AM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
Nss is poular and a great class.Tight racing with those guys.You need to install thw duwl 4's and make some test hits to se were you land.Then tune for where you want to be. GIVE EM hell!!
[Re: 69CHARGERMD]
#2301667
05/09/17 12:09 PM
05/09/17 12:09 PM
Posts: 3,838 Central Missouri Fort Leonard...
mopar65
Hey Doug how you been? The 440 in the 65 when you bought it from me , would run 10.50 in the 1/4 with 2 Edelbrock 750. But that was with a mopar M1 Tunnel Ram. So with your new engine you shouldn't have a problem hitting your ET goal
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
[Re: 69CHARGERMD]
#2302248
05/10/17 09:31 AM
05/10/17 09:31 AM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
Doug, the mod man will work but I think the indy cross ram that most of the nss racers use make way more power. Jake
JAKES AUTOMOTIVE
[Re: 69CHARGERMD]
#2302414
05/10/17 02:54 PM
05/10/17 02:54 PM
JAKE68
Shelby mi.
yes it will you may have to use one of those 2 piece valley covers.
JAKES AUTOMOTIVE
[Re: 69CHARGERMD]
#2302423
05/10/17 03:06 PM
05/10/17 03:06 PM
Posts: 17,864 S.E. Michigan
ZIPPY
S.E. Michigan
Don't think the port dimensions are going to work on this one (unless you plan on changing heads too?).
But, I am not a NSS racer so I will go back under my rock now.
Rich H.
Esse Quam Videri
[Re: JAKE68]
#2302434
05/10/17 03:25 PM
05/10/17 03:25 PM
Posts: 826 Georgia
66coronet
Georgia
Doug, the mod man will work but I think the indy cross ram that most of the nss racers use make way more power. Jake I am sure the -25 intake makes more power, but I would like to see them back to back with the same carbs just to see the difference. Mine was an existing car that I converted the induction on to become NSS legal. The modman and spacers for restrictor plates fit under my hood scoop without modification. The -25 and spacers would not. So I went the modman route.
[Re: 69CHARGERMD]
#2302592
05/10/17 10:09 PM
05/10/17 10:09 PM
Posts: 2,152 Fancy Farm Ky
wyoming
Fancy Farm Ky
I cant add any real info on the best intake to run, since all I've run in the class is either the stock crossram and the Indy one, but I will strongly recommend the DD Classic, its a great race to attend. Lots of really good cars to race, at a great old track. My advice, figure out something and drive on down.
[Re: 69CHARGERMD]
#2302674
05/11/17 12:27 AM
05/11/17 12:27 AM
JAKE68
Shelby mi.
Doug I forgot to mention the Indy requires a maxwedge port.
JAKES AUTOMOTIVE
[Re: SILVER67]
#2303025
05/11/17 09:15 PM
05/11/17 09:15 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
No chance of a single holley in the NSS classes? Ohio about as close as the races come to NY state ? The 422 club my brother races with now lets them run a single Holley. He is now using the Indy single plane intake with a Dominator. Ron
