Re: SMALL BLOCK SOLID ROLLER
[Re: moparmacka]
#2289632
04/17/17 08:09 PM
04/17/17 08:09 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Most lobes are bad. I though it may have have something to do with the intake offset rockers on my heads but it appears that the passenger side exhaust lobes show the worst signs of wear.
I was informed by a reputable cam grinder that there are cam grinders that are ignorant and/or being complacent about dressing the wheel and Not doing the opposite taper! Plus offshore quality cores don't help the situation.
That concerns me.......
I am going to check lifter location with the bad cam on a factory 360 block and then compare it to the Mopar block. Then the plan is to slip a brand new Bullet I have and see if it has the same offset. I guess it pays to check.
[Re: moparmacka]
#2289775
04/17/17 11:33 PM
04/17/17 11:33 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
I have done 5 drag weeks with roller cam small blocks with no failures. After the first drag week I did send the set back to be checked and they said they needed rebuilt and I had them do it. I never swapped them out again and had 3 drag weeks on a set of solid rollers when I pulled the 360 out in favor of a 416.
I ran comp 828-16s in the 360 with a cam that was 260ish@.050 and .650 lift. That combo loved to cruise over between 3500-4000RPM so I wasn't exactly easy on it. I also had to shift it at 7000 the last year to try and squeeze out all it had to qualify for my class. I normally tried to save that little bit for the last day lol.
I don't recall the cam specs in the 416 exactly but it is quite a bit larger than the cam in the 360 and it has way more spring. The lifters are an old MP part number but they are made by crane. We had intended to use the newer better comp roller to clear the R1 block but they were out of stock and we were out of time. It probably deserves new lifters before it does another drag week just to be safe. But at 1500-1800ish miles and 60 passes all seems well.
For what it is worth the comp 828-16s dropped right in my 360 with zero grinding, its a tight fit to drop them over that lump in the casting but they go right in. They didn't even come close to working in the R1 block the 416 has but I believe that is a well known problem.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2301431
05/08/17 11:12 PM
05/08/17 11:12 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Man I must be buying the wrong 360 blocks because on the last two blocks I've used with Comp 829 roller lifters I have had lots of grinding to get them in. And I'm not talking polishing rolls, carbide burrs
[Re: pittsburghracer]
#2301435
05/08/17 11:17 PM
05/08/17 11:17 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I will be putting together a real nice 408 in a few weeks and it will be getting Bam lifters. I never used them before but the look pretty nice
[Re: moparmacka]
#2301465
05/08/17 11:43 PM
05/08/17 11:43 PM
Bad340fish
Tulsa OK
Maybe it is because you are putting the big block 829 lifters in when you should be using the small block 828-16s. The 828-16s are close but they fit.
#2301493
05/09/17 12:28 AM
05/09/17 12:28 AM
Posts: 1,745 Maryland
340_Dart
Maryland
Man I must be buying the wrong 360 blocks because on the last two blocks I've used with Comp 829 roller lifters I have had lots of grinding to get them in. And I'm not talking polishing rolls, carbide burrs I'm with John, the last 408 I built had 828-16 lifters in it, and I spent several hours clearancing the block so that they'd drop in.
[Re: justinp61]
#2301523
05/09/17 01:16 AM
05/09/17 01:16 AM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Why aren't you guys using the Comp 8043 roller lifters? The link bar is on the inside. Up till resently I always ran Racer Brown solid lift cams in my small blocks. When I did desire to step up to a bigger cam I posted a question about what lifter to run and was pointed to the Comp 828's. Heck I still have a solid lift cam in my R3 block but when I rebuild next Winter I hope I can bring away enough safely to get the Bam roller lifters in it so I can lean on this engine some. I know I will never buy the 828's again.
[Re: moparmacka]
#2301630
05/09/17 10:51 AM
05/09/17 10:51 AM
Bad340fish
Tulsa OK
We were going to run the 8043s in the R1 416 in my car now but they were out of stock at Comp and we were out of time. I do know for sure that the 828-16s will not work in the R1 block.
