? SMALL BLOCK B1BA HEADS
#230042
02/19/09 09:51 PM
02/19/09 09:51 PM
WHAT INTAKE MANAFOLD WILL FIT. AND WHAT KIND OF ROCKERS FITS.AND WOULD THE EXH PORT WORK OUT IF PORTED IM GETING PARTS TO GETHER FOR A BIG ONE TURBO R3 BLOCK BLOW THROUGH CARB DEAL AND THIS WILL BE IN A 2700# DRAG CAR..
Re: ? SMALL BLOCK B1BA HEADS
[Re: MR_P_BODY]
#230044
02/19/09 10:01 PM
02/19/09 10:01 PM
ok
[Re: MR_P_BODY]
#230045
02/19/09 10:11 PM
02/19/09 10:11 PM
Triple Threat
Renton Washington
There are 2 versions of the brodix head, here is the summary I just copied from the Tech archives as written by Ryan J.
"Brodix B1-BA: Cast Aluminum. 59*. Closed chambers. Uses stock intake, Stock rockers, stock headers. Fully ported will flow ~300/220 cfm. More $ than E heads or W-2. Not very popular most likely due to cost. Overall a good head that is better than an Edelbrock, but no greater than W-2.
Brodix B1-BA-MC: Cast Aluminum. 59* Closed chambers. The MC stands for Moved centerline, and is designed for a bore larger than 4.10" Offset race rockers required."
Hope that helps.
[Re: Otherlane]
#230051
02/20/09 09:08 PM
02/20/09 09:08 PM
Posts: 2 Rockwood, Michigan
Lederip
Rockwood, Michigan
I know a guy that has a brand new pair with new 2.05 valves for sale.i think what he is asking for them is cheap.i will find out which head he has
I have been trying to contact that guy. If you talk to him would you please have him contact me. dakotart00@hotmail.com Thank You
#230052
02/21/09 10:37 AM
02/21/09 10:37 AM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
I assume that you have a 59° tall deck block you're using? In my opinion there are a lot of better heads out there then the b1-ba. I would even venture to say a fully ported set of Edelbrocks may even be better/as good as a set of fully ported b1-ba heads. The MC stuff is suppose to be better, but I haven't ever heard of or seen any out there that run all that great. Here's an old post with some info... https://board.moparts.org/ubbthreads/show...t=1#Post3074248
