? SMALL BLOCK B1BA HEADS #230042
02/19/09 09:51 PM
02/19/09 09:51 PM
Anonymous OP
Anonymous OP
WHAT INTAKE MANAFOLD WILL FIT. AND WHAT KIND OF ROCKERS FITS.AND WOULD THE EXH PORT WORK OUT IF PORTED IM GETING PARTS TO GETHER FOR A BIG ONE TURBO R3 BLOCK BLOW THROUGH CARB DEAL AND THIS WILL BE IN A 2700# DRAG CAR..
Re: ? SMALL BLOCK B1BA HEADS #230043
02/19/09 09:58 PM
02/19/09 09:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Do us a favor... turn your caps lock off... thanks
Re: ? SMALL BLOCK B1BA HEADS [Re: MR_P_BODY] #230044
02/19/09 10:01 PM
02/19/09 10:01 PM
Anonymous OP
Anonymous OP
ok
Re: ? SMALL BLOCK B1BA HEADS [Re: MR_P_BODY] #230045
02/19/09 10:11 PM
02/19/09 10:11 PM
Renton Washington
Triple Threat Offline
Renton Washington
There are 2 versions of the brodix head, here is the summary I just copied from the Tech archives as written by Ryan J.
"Brodix B1-BA: Cast Aluminum. 59*. Closed chambers. Uses stock intake, Stock rockers, stock headers. Fully ported will flow ~300/220 cfm. More $ than E heads or W-2. Not very popular most likely due to cost. Overall a good head that is better than an Edelbrock, but no greater than W-2.
Brodix B1-BA-MC: Cast Aluminum. 59* Closed chambers. The MC stands for Moved centerline, and is designed for a bore larger than 4.10" Offset race rockers required."
Hope that helps.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: ? SMALL BLOCK B1BA HEADS #230046
02/19/09 10:29 PM
02/19/09 10:29 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
All stock LA intakes work. You can if you like use small block chevy rockers with studs and guide plates and oil thru the pushrods,or use the Brodix blocks and stock shaft rockers. You will need to make china wall spacers or double end gaskets.
Re: ? SMALL BLOCK B1BA HEADS [Re: goldmember] #230047
02/20/09 08:43 AM
02/20/09 08:43 AM
east coast
Otherlane Offline
Otherlane  Offline
east coast
I know a guy that has a brand new pair with new 2.05 valves for sale.i think what he is asking for them is cheap.i will find out which head he has
Re: ? SMALL BLOCK B1BA HEADS [Re: Otherlane] #230048
02/20/09 04:27 PM
02/20/09 04:27 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Sounds like a Trick Bag to me
Re: ? SMALL BLOCK B1BA HEADS [Re: 340RICK] #230049
02/20/09 06:01 PM
02/20/09 06:01 PM
Orlando Fl
Dos Snails Offline
Dos Snails  Offline
Orlando Fl
I've seen two different new sets listed here in florida for $800...
Re: ? SMALL BLOCK B1BA HEADS [Re: Dos Snails] #230050
02/20/09 07:51 PM
02/20/09 07:51 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
As an owner of a pair, that are ported by a professional shop, I would suggest moving on to something else. There are a better choices out there.
Leigh
Re: ? SMALL BLOCK B1BA HEADS [Re: Otherlane] #230051
02/20/09 09:08 PM
02/20/09 09:08 PM
Rockwood, Michigan
Lederip Offline
Lederip  Offline
Rockwood, Michigan
I have been trying to contact that guy. If you talk to him would you please have him contact me.
dakotart00@hotmail.com
Thank You
Re: ? SMALL BLOCK B1BA HEADS #230052
02/21/09 10:37 AM
02/21/09 10:37 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I assume that you have a 59° tall deck block you're using?
In my opinion there are a lot of better heads out there then the b1-ba. I would even venture to say a fully ported set of Edelbrocks may even be better/as good as a set of fully ported b1-ba heads.
The MC stuff is suppose to be better, but I haven't ever heard of or seen any out there that run all that great.
Here's an old post with some info...
https://board.moparts.org/ubbthreads/show...t=1#Post3074248
Re: ? SMALL BLOCK B1BA HEADS [Re: dizuster] #230053
02/21/09 07:45 PM
02/21/09 07:45 PM
east coast
Otherlane Offline
Otherlane  Offline
east coast
As soon as I get a hold of dude I will let u know. When I blew my engine I wanted something than indy heads so I talk to ryanj about the brodix heads and he talked me into W heads.But there's a guy at the track running brodix heads and 3.79 crank I've seen 10.20 but heard it goes 9.70s. Grudge racers.
