Chemical dipping
#2300048
05/06/17 12:43 PM
05/06/17 12:43 PM
Posts: 8,880 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Searching the web I found this on a site and thought it was interesting enough to post here. I've personally tossed a spring or two in an acid solution that would normally only remove rust - only to have them completely disappear! So I thought this would be informative for people who need to restore various springs. Will the acid damage the metal? The acid we use will not damage your sheetmetal parts. We use phosphoric acid that's been used for decades to treat rusted surfaces for paint. Another misconception from the internet or somewhere. Let me state it again: the acid WILL NOT damage your sheetmetal panels, parts, bodies, or cabs. There are a few types of metals that the acid will damage: cast parts, spring metals, & pot metal. We can still clean cast parts and spring parts like seat springs. However, most of the cleaning on these types of metal items is done in the hot tank. Cast parts and spring material parts get only a very light acid treatment to ensure no damage is done to them. I know there was someone on here a while back who had a window regulator spring deteriorate and fall apart in Evaporust
Re: Chemical dipping
[Re: Stanton]
#2300530
05/07/17 06:06 AM
05/07/17 06:06 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Shell ONLY - you're close to 3 G's by the time you add doors, fenders, trunk lid, hood, etc. Yes but IIRC the place in Ohio was over 6K with e-coating Plus you needed to build a fixture for your body because the car has to go in sideways as the tanks are not wide enough
[Re: Adam71Charger]
#2300595
05/07/17 11:25 AM
05/07/17 11:25 AM
Morty426
Sacramento CA
Ive always been intrigued by acid dipping a uni body. Ideally, it would attack all the spots on the body that are hard to get to by any other method. But, if the car was anything but but solid with only surface rust, wouldn't an acid dip cause some of the more heavily rusted areas on a typical older car to basically disappear? Basically, is acid dipping only a process that safely works for cars that are already in pretty good condition (metal wise)? Well the rust isn't holding anything together so what is the issue?
[Re: Stanton]
#2300614
05/07/17 11:55 AM
05/07/17 11:55 AM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I've always been intrigued by acid dipping a uni body. Ideally, it would attack all the spots on the body that are hard to get to by any other method. But, if the car was anything but but solid with only surface rust, wouldn't an acid dip cause some of the more heavily rusted areas on a typical older car to basically disappear? Basically, is acid dipping only a process that safely works for cars that are already in pretty good condition (metal wise)? If you go to site I posted in the second post, they have a Q & Q page that will answer every question you ever had. MOST places (and there aren't many to begin with) don't do an e-coat. The big difference being the business model - dippers are in business to remove coatings, e-coaters are in business to apply them. I only found one (in Vancouver, Canada) that offers a zinc coating after stripping.
