Re: 4.10's in a ram 1500 with the 20" wheels [Re: racerx] #2298950
05/04/17 03:44 PM
05/04/17 03:44 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I have to eat my words on my 15 Rammit. It has the high gears, 6 speed and around town it is a bit gutless. I didn't think it had the guts to tow a trailer but I was wrong.
We have a hill heading out of my old town that is 8% and runs for around 10 miles. I loaded this mother down with my 4000lb Stealth in the back of the 26 ft trailer and around 2500lbs in the front of the trailer and the back of the truck. She buzzed up that hill just fine at 50MPH. She would have pulled up there faster but I kept the revs to around 3500 and she held it just fine.
And guess what else? On the 500 mile trip she got 9MPG overall, which is maybe 1 to 2 MPG less than my old 05 Cummins would have done.
I don't think you need a gear change with your ecodiesel but that's just my opinion. My truck is not optioned optimally to pull but it does it just fine.
My truck came with 17's and I switched to the 20's tire circumference is 5% larger than the 17's.
Sheldon
Re: 4.10's in a ram 1500 with the 20" wheels [Re: racerx] #2299086
05/04/17 07:22 PM
05/04/17 07:22 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
? I assume were talking 3.90's rear gear? work
Re: 4.10's in a ram 1500 with the 20" wheels [Re: racerx] #2299230
05/04/17 10:51 PM
05/04/17 10:51 PM
tulsa ok
U
upnover Offline
upnover  Offline
U
tulsa ok
factory 20" tires on the 4x4's are 33" tall, the 275/60/20 thats why most come with a 3.9 gear due to the 33" height. 3.55s are too high for 33's. the newer trucks with the 6 or 8 speed trannies can get away with the higher gears
Re: 4.10's in a ram 1500 with the 20" wheels [Re: upnover] #2299241
05/04/17 11:16 PM
05/04/17 11:16 PM
RUNCHARGER Offline
RUNCHARGER  Offline
Mine has 3.55. As I said it is totally the non optimal setup for towing and it kicked azz anyway. 1500, six speed, 3.55, 20 inch wheels and pulling about 11,000lbs over a 10 mile long 8 percent grade. I can't call it my girly truck anymore.
Sheldon
Re: 4.10's in a ram 1500 with the 20" wheels [Re: racerx] #2299289
05/05/17 12:40 AM
05/05/17 12:40 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
I figured you would come around and like your new truck sometime. wink
Little update on my '01 360 Mag above:
Towed a '98 QC 4x4 (5500lbs) on a heavier trailer (2500lbs) and started the trip at 10.5mpg and by the time I got home (350 miles) the average wound up at 13.0mpg
45 to 55mph in third on all the mean hills and stayed in top gear on the level at 60mph.
Nope, still don't miss my old '02 Cummins.
Mo' Farts
Moderated by "tbagger".
Re: 4.10's in a ram 1500 with the 20" wheels [Re: upnover] #2299378
05/05/17 08:03 AM
05/05/17 08:03 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Any ideal what transmission in the 2000-03 rams?46r or what tranny?
Re: 4.10's in a ram 1500 with the 20" wheels [Re: racerx] #2299920
05/06/17 06:51 AM
05/06/17 06:51 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
46 RE until 03, they made some changes
Re: 4.10's in a ram 1500 with the 20" wheels [Re: racerx] #2300030
05/06/17 12:16 PM
05/06/17 12:16 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Any ideal what changes ,did they go 5 speed?Thaxs..... up
Re: 4.10's in a ram 1500 with the 20" wheels [Re: racerx] #2300446
05/07/17 12:27 AM
05/07/17 12:27 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The 03 Ram with the Hemi we parted out had a 5 speed auto. Have no idea if it was an option, or an across the board change, or a Hemi deal.
Gene
Re: 4.10's in a ram 1500 with the 20" wheels [Re: racerx] #2300557
05/07/17 09:21 AM
05/07/17 09:21 AM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
Our 09 ram r/t. (They only come with 4.10 gears) 5 speed Auto. I towed Mt open 23 steel floor trailer 71 charger down to ar. Other then bumps never it was back there and I never turned the overdrive off 75-80 most the way. Was just like normal driving (under 2k on the tach) truck also had 20" wheels
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
