Re: Moroso 7 quart pan, 7 or 8 quarts total?
[Re: Nitrofish]
#2300397
05/06/17 11:28 PM
05/06/17 11:28 PM
Posts: 11,551 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
7 quarts plus whatever the filter, accusump, etc., holds. Get a quart container, add water a quart at a time up to the baffle, tray, full mark or wherever the oil level should be to verify. I expect 8 quarts total is fine.
[Re: Nitrofish]
#2300654
05/07/17 01:03 PM
05/07/17 01:03 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I have that pan and it's 8 quarts with filter.Not to disagree with Ron,but that's what my pan takes to fill it.The pan is a old one,purchased in 1973 by my Dad.
[Re: Nitrofish]
#2301706
05/09/17 01:06 PM
05/09/17 01:06 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Actually I should add its more like 7-1/2 qts to fill mine as I add a botle of the zinc additive when I change the oil. I use a stock dipstick and it reads a hair over the full mark with the 7-1/2. But I know from years at the Dodge dealer not all factory dipsticks read right on the money. We had a few that had TSB's where we had to cut some off the dipstick tube as some were just to long and still read low with the proper amount of oil. So I may have the same 8 qt pan as maybe my dipstick tube is of a little ? I have no problem with 7 or 8 qts as I only race about once a year and even with just 7 qts its no problem. Ron
