Re: Best Product to rejunivate Orig. Weatherstriping
[Re: Imrare]
#2299607
05/05/17 04:44 PM
05/05/17 04:44 PM
Posts: 2,092 New Mexico
JMCFAN
New Mexico
A good scrubbing with Simple Green and then a wipe with 303 made mine look like new....
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
[Re: Stanton]
#2299650
05/05/17 06:22 PM
05/05/17 06:22 PM
Posts: 291 St. Louis
Imrare
St. Louis
[Re: Stanton]
#2299807
05/05/17 11:09 PM
05/05/17 11:09 PM
Posts: 8,271 fredericksburg,va
cudaman1969
fredericksburg,va
U[quote=Stanton]You could use the same stuff they use to rejuvenate condoms
[Re: Stanton]
#2300006
05/06/17 11:40 AM
05/06/17 11:40 AM
Posts: 306 Georgia
69bfan
Georgia
I had much rather have 45 plus year old weatherstripping than many of the reproduction pieces and I am involved in the manufacturing and selling of weatherstripping. The sun does more damage to the product than the other weather elements. So cars out of the extreme Southwest and extreme Southeast typically may be dried out and cracked. But otherwise, as long as it is not torn, most door seals and roofrail seals can be cleaned up and brought back to life. Lacquer thinner and a soft cleaning with a rag will remove paint overspray with time. Once clean, simply soak in a good cleaning solution as Simple Green or Royal Purple. Both of these cleaners can be quite strong, so do not allow them to simply sit for extended periods. Once clean, various manufactures like Mothers and Meriguiers make good treatment products. Do not hang the seals for extended periods say from rafters or ladders. They will stretch over a extended period. Just simply lay on a surface in a loose loop and do not lay anything on them. You will save yourself $100 plus and maintain an original part to the car and the seals will work much better than any of the reproductions.
www.restorationpartsandmaterials.comCorrect Mopar weatherstripping is our specialty, but we stock and supply a wide assortment for all of your restoration needs. www.dalescudashop.comCorrect style exhaust tips and hardware, fresh air seals, go wings, Cuda & Challenger rear window louvers, hood pin kits
[Re: Imrare]
#2301162
05/08/17 02:07 PM
05/08/17 02:07 PM
Posts: 381 Ottawa, Ontario
L.R Helbling
Ottawa, Ontario
What is the best "rubber rejuvenator" to use on my original 1970 roof rail weather stripping? It may be worth your while to try a product that protects against UV rays as well as protect and soften your original 1970 roof rail weatherstripping. If your strips are not rotten, I'd go with Aerospace 303. Especially if these get blasted by the sun when you're out.
[Re: Imrare]
#2302103
05/09/17 11:52 PM
05/09/17 11:52 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
303 can be purchased at Advance Auto Parts
