A/C evaporator removal
#2299536
05/05/17 02:10 PM
05/05/17 02:10 PM
Posts: 43 Sahuarita, Arizona
ChuxGTX
Sahuarita, Arizona
Hi all, I'm working on the A/C heater box from my 68 GTX and would like some advice on removing the evaporator. the tubes exiting the box (drain tubes?) have a flange that is larger than the hole they pass through, preventing removal of the evaporator. Before I cut them off and commit to buying a new one or sweating these back together, I thought I would ask what other people have done at this point. [img:left] [/img] [img:left] [/img] Thanks for any help
Re: A/C evaporator removal
[Re: ChuxGTX]
#2299550
05/05/17 02:30 PM
05/05/17 02:30 PM
Posts: 2,861 Pattison Texas
CSK
Pattison Texas
they will come off,spray some penetrate oil & work them gently , if that dont work,put a LITTLE heat to them.
