Re: Dakota Ac
[Re: 493_DART]
#2299556
05/05/17 02:42 PM
05/05/17 02:42 PM
Posts: 25,796 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Did you check the pressure with a single gauge or a manifold set? Only dual gauges will show the pressure readings you need to determine if it's over or under charged.
I'll repeat my previous rant, the only way to properly charge an A/C system is by weight i.e. total discharge and recharge by weight.
Re: Dakota Ac
[Re: 493_DART]
#2299782
05/05/17 10:17 PM
05/05/17 10:17 PM
Posts: 733 jacksonville,FLORIDA
slammedR/T
96 Dakota is an expansion valve system and should not be cycling the a/c compressor like that. You need to put a real manifold gauge set on there and see what is going on, also that system if I remember correctly will hold 36oz from empty fill.
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
