1971 Road Runner Running Issue #2298994
05/04/17 04:50 PM
05/04/17 04:50 PM
NEW JERSEY
moparfury1970 Offline OP
NEW JERSEY
Hey guys, so I'm about ripping the last of my hair out trying to figure out what exactly is going on. Here's the scoop:
I took my car out and drove it on the highway for about an hour and had a total loss of power. Pulled over, started up and twenty minutes later, same thing, loss of power. While this is happening, mind you, I'm getting severe backfires. I get home and troubleshoot. Swap out the ignition module and install one of those orange ones. I'm wire for 5 prongs, but have used 4 prong ignition modules in the past. I also have a 4 prong ballast resistor. I took it out the other day and it ran fine. Today, I take the car out and it ran well until I decided to accelerate. I got exhaust pop on deceleration and the engine seemed to run rough (shaking a bit) when accelerating. I swapped out another ignition module, ballast resistor and pickup coil to see if it would remedy the situation. Nothing. Any thoughts?
Re: 1971 Road Runner Running Issue [Re: moparfury1970] #2299001
05/04/17 04:58 PM
05/04/17 04:58 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Sounds like a weak fuel pump to me. Had this same thing happen on my carbed jeep. I had a vapor return style fuel filter on there and I figured out it must have been returning more than my weak fuel pump could push when it got hot. I clamped off the return line completely and that was a temporary fix until I replaced the fuel pump with an electric one back at the tank.
Re: 1971 Road Runner Running Issue [Re: moparfury1970] #2299004
05/04/17 05:04 PM
05/04/17 05:04 PM
Ottawa, Ontario
L.R Helbling Offline
Ottawa, Ontario
First do a resistance test on your ignition coil to see if the resistances on primary and secondary side of the coil are within tolerance. Check the coil service manual for ohm resistances to check. If it is a factory coil, check the FSM for ohm resistances to check. If they are not, junk the coil. If they are, continue with a dynamic test and wear rubber gloves and eye protection. With your car running, pull the high tension lead from your coil at the coil very slowly. The spark should jump a gap of an inch or so visibly and audibly with no trouble. If it is not, if it is sputtering and quiet your coil is fried possibly because of your 4 prong ballast which does not match your existing coil.
Had the same thing happen to my 1971 Roadrunner with the exact same symptoms. It may be worth a try.
Re: 1971 Road Runner Running Issue [Re: moparfury1970] #2299014
05/04/17 05:13 PM
05/04/17 05:13 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
"Loss of power". Are you saying the car would die and not even crank for a little bit?
Re: 1971 Road Runner Running Issue [Re: buildanother] #2299021
05/04/17 05:23 PM
05/04/17 05:23 PM
NEW JERSEY
NEW JERSEY
I just started it up again. Starts up fine, idles fine. When I accelerate, it seems like the engine can't get past a certain rpm. It's happening just under 30mph. It's the most bizarre thing.
Re: 1971 Road Runner Running Issue [Re: L.R Helbling] #2299022
05/04/17 05:26 PM
05/04/17 05:26 PM
NEW JERSEY
NEW JERSEY
What coil would match a 4 prong ballast resistor? Right now I have a 12v red MSD coil.
Re: 1971 Road Runner Running Issue [Re: moparfury1970] #2299030
05/04/17 05:38 PM
05/04/17 05:38 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
8203 msd coil comes with the resistor that they want you to use with it.
Re: 1971 Road Runner Running Issue [Re: moparfury1970] #2299039
05/04/17 05:57 PM
05/04/17 05:57 PM
NEW JERSEY
NEW JERSEY
I just looked at the fuel filter too. Barely has anything in it.
Re: 1971 Road Runner Running Issue [Re: moparfury1970] #2299049
05/04/17 06:07 PM
05/04/17 06:07 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
Not one of the cheap clear filters with chrome ends on it I hope. I have seen them look like nothing in them and not let hardly any fuel through.
Re: 1971 Road Runner Running Issue [Re: moparfury1970] #2299051
05/04/17 06:13 PM
05/04/17 06:13 PM
NEW JERSEY
NEW JERSEY
no, it's a napa gold filter that I've always used.
Re: 1971 Road Runner Running Issue [Re: moparfury1970] #2299066
05/04/17 06:50 PM
05/04/17 06:50 PM
do you have another ign coil that you can borrow/sub in for a quick test.
Re: 1971 Road Runner Running Issue [Re: moparfury1970] #2299069
05/04/17 07:02 PM
05/04/17 07:02 PM
NEW JERSEY
NEW JERSEY
yes,i swapped out the msd with a yellow accel super coil. car doesn't seem to be acting now.
Re: 1971 Road Runner Running Issue [Re: moparfury1970] #2299079
05/04/17 07:15 PM
05/04/17 07:15 PM
All good or still acting up? EDIT Accell wants a .7 ohm ballast with that big yellow beast & your 4 terminal "dual" ballast will for sure have more than that. You might wire it in parallel (just add a blue loop on the other end also) to get the most out of this combo. That will work fine with your 4 pin ecu.
Re: 1971 Road Runner Running Issue [Re: moparfury1970] #2299082
05/04/17 07:18 PM
05/04/17 07:18 PM
Ottawa, Ontario
Ottawa, Ontario
Whatever coil can work when matched to the resistance of your 4 prong ballast. If you really want to keep the 4 prong, test it to make sure it really does have a resistance of??? i dunno...let's say it's supposed to be 1 ohm. If you read 1 ohm on your multi-meter, shop around for a coil that will work with a resistance of 1 ohm. It should be marked on the underside of the ballast but if not there do a Google search to see what it's resistance should be. But first make sure your coil is bad before you start doing all that.
Re: 1971 Road Runner Running Issue [Re: moparfury1970] #2299085
05/04/17 07:20 PM
05/04/17 07:20 PM
Ottawa, Ontario
Ottawa, Ontario
Sounds good. can you get the spec for the yellow Accel if you are going to leave it in the car? It would be nice to know what ballast resistor is needed with that coil.
Re: 1971 Road Runner Running Issue [Re: moparfury1970] #2299121
05/04/17 08:09 PM
05/04/17 08:09 PM
NEW JERSEY
NEW JERSEY
Thanks for all the info gents. I will get the specs for the yellow Accel. I think I'm leaving it. The car is now accelerating without issues. Some exhaust popping, but that's on the deceleration. I can tune the carb up some. I will keep you guys updated.
Re: 1971 Road Runner Running Issue [Re: moparfury1970] #2299137
05/04/17 08:34 PM
05/04/17 08:34 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Did you say what kind of distributor you had?
Re: 1971 Road Runner Running Issue [Re: moparfury1970] #2299139
05/04/17 08:40 PM
05/04/17 08:40 PM
NEW JERSEY
NEW JERSEY
It's a mopar performance distributor (brown cap). It came with the orange box and 2 prong ballast resistor
Re: 1971 Road Runner Running Issue [Re: moparfury1970] #2299160
05/04/17 09:19 PM
05/04/17 09:19 PM
the last 4 terminal "dual" ballast I parallel wired gave me 1.1 ohms which will work fine & is above the .7 ohms Accell wants for a minimum with their supercoil & that amt (1.1) is lower than what your 2 terminal "single" ballast will have. EDIT Assuming you don't have the 641 MP "race" 2 terminal "single" ballast (has .25 nominal ohms).
Re: 1971 Road Runner Running Issue [Re: moparfury1970] #2299167
05/04/17 09:27 PM
05/04/17 09:27 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Your problem is ignition not fuel. Did you change out the orange box or visa versa? My bets are on the box. Do you have any other spare boxes? Also, it may be the box is not grounding. I had a similar issue with an orange box. Is the box bolted to firewall? You may want to run a separate ground wire from the box to a common ground. I did that and it was problem solved.
Abe Lincoln
