SST Electric steering #2295083
04/27/17 04:02 PM
04/27/17 04:02 PM
Eau Claire, WI
Charger727 Offline OP
Eau Claire, WI
Saw this on the Mopar Connection advertising "magazine" -
https://shiftsst.com/store/electric-power-steering/mopar.html
Looks interesting, kind of pricey - opinions?
Re: SST Electric steering [Re: Charger727] #2295242
04/27/17 08:36 PM
04/27/17 08:36 PM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
Is this for a car with a manual steering box? I predict they will sell about none...
A new iron curtain drawn across the 49th parallel
Re: SST Electric steering [Re: 67autocross] #2295299
04/27/17 10:12 PM
04/27/17 10:12 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
They may sell a few. A good power steering box will run you several hundred, plus lines, a pump and maybe a cooler. Depends on the application though, I don't think it's something I would want to deal with in the aftermarket, however.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: SST Electric steering [Re: Charger727] #2295341
04/27/17 11:17 PM
04/27/17 11:17 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
All they did was take a late model electric power steering setup and package it as a "kit".
http://forums.vintage-mustang.com/mod-cu...ere-you-go.html
Don't be the exception.
Re: SST Electric steering [Re: Supercuda] #2295445
04/28/17 03:07 AM
04/28/17 03:07 AM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
Pretty sure the hotchkis built dart is running electric assist. Nice option that you can 'hide' under the dash
Re: SST Electric steering [Re: Charger727] #2297948
05/02/17 10:19 PM
05/02/17 10:19 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I wonder if it can be hacked!
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: SST Electric steering [Re: astjp2] #2298180
05/03/17 11:11 AM
05/03/17 11:11 AM
Eau Claire, WI
Eau Claire, WI
Maybe I can steer using my smartphone! smile
Re: SST Electric steering [Re: Charger727] #2298659
05/04/17 01:37 AM
05/04/17 01:37 AM
TX
CBODY67 Offline
CBODY67  Offline
TX
Seems like Flaming River or Ididit has an electric ps column for the street rod market? Key thing would be how to control the "boost". With an inexpensive controller, using salvage yard items, costs would be lower. Even the "normal" GM-replacement columns from FR or Ididit are over $700.00, so $1K for an self-contained electric ps unit seems more reasonable.
The basic column from a Chevy Malibu (square rear end styling) was the first electric ps unit from GM NA. It's a compact section with the motor. About 30" in length for that part of the total column. Almost all GMs now use electric ps. It's nice to not have to worry about a squealing power steering belt! Plus less load on the engine.
Collapsible column now is done with a "slip length" in the intermediate shaft between the rack and the end of the column.
"Electric Power Brakes" was mentioned in the Mustang forum post. GM tried that in the middle 1980s with the "PowerMaster" booster. Used an electric pump to "empty" the reservoir into a pressure bulb. Looked different in operation! Stopped engine = full reservoir Running engine = almost empty reservoir, which was normal, but looked flaky with the clear plastic reservoirs.
Problems existed, so it only lasted a few model years. Every mid-1980s Chevy Caprice wagon (vacuum booster equipped) in the salvage yard was "sans booster" for that reason. Just too different for the times.
CBODY67
66-CL42, 67-CE23, 70-DH43 Each under about 25K built. Numbers decrease with options and colors! How'd I manage that?
