Magnum heads and cam #229808
02/19/09 04:16 PM
02/19/09 04:16 PM
Caldwell. Id
E
edbux Offline OP
edbux  Offline OP
E
Caldwell. Id
I was looking at a cam with the following specs:
(214 230 duration at 50 on 109 lobe sep with .501 and .522 lift WITH 1.6 rockers)
It's similar to the Hughes Whiplash cams, smaller lift though. Would this lift work with Magnum heads? Valve springs will be changed to accommodate the cam. I was thinking there may be an issue with the valve guides, if not more.
1967 Dart 270 360/727
Re: Magnum heads and cam [Re: edbux] #229809
02/19/09 05:24 PM
02/19/09 05:24 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
it's going to be close with the valve guides...'bout the only way to know for sure would be to mock it up.
2017 Grand Cherokee Overland
