Re: Hemi stoker guys step inside: [Re: hudsonhornet7x] #2297137
05/01/17 02:05 PM
05/01/17 02:05 PM
Originally Posted By hudsonhornet7x
Thanks for the replies. Even though I found a deal on the pistons it seems like I should be looking at bigger cubes.
Have you thought of using a shorter rod length with the longer stroke to use those pistons? work
I have made the mistake of buying a part and then building a motor around that part tsk That is not the smartest way to start on a new motor build unless your absolutely sure you want to build that new motor that way work
Re: Hemi stoker guys step inside: [Re: Cab_Burge] #2297139
05/01/17 02:08 PM
05/01/17 02:08 PM
USA
hudsonhornet7x Online content OP
hudsonhornet7x  Online Content OP
USA
I have thought about it, but don't know how good that would be.
Re: Hemi stoker guys step inside: [Re: hudsonhornet7x] #2297160
05/01/17 02:35 PM
05/01/17 02:35 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
I had a 4.150 crank in mine. I started out just adding some alum edelbrock heads. After getting them back from modern I also decided to step up to a 4.5 crank. I'd like to drag the rpm range down a bit and pull some gear out. It'll still be a street motor.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: Coal stoker guys step inside: [Re: 68 HEMI GTS] #2297299
05/01/17 06:14 PM
05/01/17 06:14 PM
dogdays Offline
dogdays  Offline
So Hudson, what is the compression height of your pistons? How about pin size?
R.
Re: Coal stoker guys step inside: [Re: dogdays] #2297401
05/01/17 09:22 PM
05/01/17 09:22 PM
USA
USA
R.
Here is a pic. Haven't bought them yet.
Re: Coal stoker guys step inside: [Re: hudsonhornet7x] #2301788
05/09/17 03:32 PM
05/09/17 03:32 PM
dogdays Offline
dogdays  Offline
At first glance it appears you could use them with a 4.400 stroke and 6.76 rods.
that's the aftermarket stock length for B/RB crank
10.725 - 1.765 - 6.760 -2.20 = 0
Or easy as pie 4.5" stroker with 6.700 inch rod, piston a little below deck.
Easy as ordering the crank and rods.
So while I was originally going to say don't do it, it appears it may really be a good deal. 528 cubic inches with Hemi heads sitting on top should equal huge power and torque.
R.
